AidGen SDK Developer Documentation
Introduction
AidGen is an inference framework specifically designed for generative Transformer models, built on top of AidLite. It aims to fully utilize various computing units of hardware (CPU, GPU, NPU) to achieve inference acceleration for large models on edge devices.
AidGen is an SDK-level development kit that provides atomic-level large model inference interfaces, suitable for developers to integrate large model inference into their applications.
AidGen supports multiple types of generative AI models:
- Language large models -> AidLLM inference
- Multimodal large models -> AidMLM inference
The structure is shown in the diagram below:
All large models supported by Model Farm achieve inference acceleration on Qualcomm chip NPUs through AidGen.
Support Status
Model Type Support Status
| AidLLM | AidMLM | |
| Text | ✅ | / |
| Image | / | ✅ |
| Audio | / | 🚧 |
✅: Supported 🚧: Planned support
Operating System Support Status
| Linux | AidLux | Android | |
| C++ | ✅ | ✅ | / |
| Python | 🚧 | 🚧 | / |
| Java | / | / | 🚧 |
Large Language Model AidLLM SDK
Installation
sudo aid-pkg -i aidgen-sdk
# copy test code
cd /home/aidlux
cp -r /usr/local/share/aidgen/examples/cpp/aidllm .Model File Acquisition
- Model files and default configuration files can be downloaded directly through the Model Farm Large Model Section
- Retrieve and Download Models via
mms(Using Qwen2.5-0.5B-Instruct as an example)
# Log in
mms login
# Search for the model
# Download the model
# Parameters:
# -m: Model Name, -p: Precision (w4a16), -c: Chipset (qcs8550)
# -b: Backend/QNN Version (qnn2.29), -d: Destination Directory
unzip qnn229_qcs8550_cl2048
mv qnn229_qcs8550_cl2048/* /home/aidlux/aidllm/Model Performance Monitoring
Please ensure that the sample application can be executed successfully in its entirety.
Taking the example Deploying Qwen2.5-0.5B-Instruct on Qualcomm QCS8550
# Install dependencies
sudo apt install libfmt-dev
# Compile
mkdir build && cd build
cmake .. && make
mv test_prompt_serial /home/aidlux/aidllm/
# Run after successful compilation
# The first parameter `1` enables profiler statistics
# The second parameter `1` specifies the number of inference iterations
./test_prompt_serial qwen2.5-0.5b-instruct-htp.json 1 1- After entering the conversation content in the terminal, you will see the following log information:
Example
- Deploying Qwen2.5-0.5B-Instruct on Qualcomm QCS8550
- Deploying Qwen3 Series on Qualcomm QCS8550
- Deploying HY-MT1.5-1.8B on Qualcomm QCS8550
Multi-modal Vision Model AidMLM SDK
Model Support Status
| Model | Status |
| Qwen2.5-VL-3B-Instruct | ✅ |
| Qwen2.5-VL-7B-Instruct | ✅ |
| InternVL3-2B | 🚧 |
| Qwen3-VL-4b | 🚧 |
| Qwen3-VL-2b | 🚧 |
Installation
# copy test code
cd /home/aidlux
cp -r /usr/local/share/aidgen/examples/cpp/aidmlm ./Model File Acquisition
Acquire and download models directly via command line.
mms login
mms list Qwen2.5-VL-3B
mms get -m Qwen2.5-VL-3B-Instruct_392x392_ -p w4a16 -c qcs8550 -b qnn2.36 -d /home/aidlux/aidmlm/qwen2.5-vl-3b-392
unzip qnn236_qcs8550_cl2048
mv qnn236_qcs8550_cl2048/* /home/aidlux/aidmlm/Create Configuration File
vim config3b_392.jsonCreate the following json configuration file:
"llm_path_list":[
}The file distribution is as follows:
/home/aidlux/aidmlm
├── CMakeLists.txt
├── test_qwen25vl_abort.cpp
├── test_qwen25vl.cpp
├── full_attention_mask.raw
├── position_ids_cos.raw
├── position_ids_sin.raw
├── veg.serialized.bin.aidem
├── window_attention_mask.rawModel Performance Monitoring
Taking the example Deploying Qwen2.5-VL-3B-Instruct (392x392) on Qualcomm QCS8550
sudo apt-get install libfmt-dev nlohmann-json3-dev
cmake .. && make
mv test_qwen25vl /home/aidlux/aidmlm/
./test_qwen25vl "qwen25vl3b392" "config3b_392.json" "demo.jpg" "Please describe the scene in the picture" 1- After entering the conversation content in the terminal, you will see the following log information:
Example
Modifying Inference Parameters
AidGen supports dynamic modification of parameters related to model inference. Currently supported parameters include:
- temp
- top-k
- top-p
Refer to the following code in the test_prompt_abort.cpp file to modify parameters:
int ret = llm_interpreter_ptr->set_sampler("temp", "0.5");
ret = llm_interpreter_ptr->set_sampler("top-p", "0.8");
ret = llm_interpreter_ptr->set_sampler("top-k", "20");
