Deploying LLM with AidGen
Introduction
Deploying a Large Language Model (LLM) on edge devices refers to compressing, quantizing, and deploying large models that originally run in the cloud to local devices, enabling offline, low-latency natural language understanding and generation. This chapter demonstrates how to complete the deployment, loading, and dialogue process of a large language model on an edge device based on the AidGen inference engine.
In this case, the large language model inference runs on the device side, and relevant interfaces are called through C++ code to receive user input and return dialogue results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-0.5B-Instruct
Supported Platforms
PlatformRunning Method
Preparation
  1. Rhino Pi-X1 hardware
  3. Prepare model files
    Visit Model Farm: Qwen2.5-0.5B-Instruct to download the model resource files.
Select the QCS8550 chip.
Case Deployment
Step 1: Install AidGen SDK
# Install AidGen SDK
sudo aid-pkg -i aidgen-sdk
# Copy test code
cd /home/aidlux
cp -r /usr/local/share/aidgen/examples/cpp/aidllm .
Step 2: Upload & Unzip Model Resources
  • Upload the downloaded model resources to the edge device.
  • Unzip the model resources to the /home/aidlux/aidllm directory:
cd /home/aidlux/aidllm
unzip Qwen2.5-0.5B-Instruct_Qualcomm\ QCS8550_QNN2.29_W4A16.zip -d .
Step 3: Confirm Resource Files
/home/aidlux/aidllm
├── CMakeLists.txt
├── test_prompt_abort.cpp
├── test_prompt_serial.cpp
├── aidgen_chat_template.txt
├── chat.txt
├── qwen2.5-0.5b-instruct-htp.json
├── qwen2.5-0.5b-instruct-tokenizer.json
├── qwen2.5-0.5b-instruct_qnn229_qcs8550_4096_1_of_2.serialized.bin
├── qwen2.5-0.5b-instruct_qnn229_qcs8550_4096_2_of_2.serialized.bin
Step 4: Set Dialogue Template
For the dialogue template, refer to the aidgen_chat_template.txt file in the model resource package.
Modify the test_prompt_serial.cpp file according to the large model's template:
    if(prompt_template_type == "qwen2"){
        prompt_template = "<|im_start|>system\nYou are Qwen, created by Alibaba Cloud. You are a helpful assistant.<|im_end|>\n<|im_start|>user\n{0}<|im_end|>\n<|im_start|>assistant\n";
Step 5: Compile and Run
# install dependency
sudo apt install libfmt-dev
# compile
mkdir build && cd build
cmake .. && make
# Run test_prompt_serial after successful compilation
./build/test_prompt_serial qwen2.5-0.5b-instruct-htp.json
  • Enter dialogue content in the terminal.
