AidGen C++ API
AidGen C++ API Documentation
AidGen 2.x C++ API Documentation
Before developing with AidGen-SDK 2.x C++, please be aware of the following basics:
- During compilation, include the header file located at
/usr/local/include/aidlux/aidgen/aidgen.hpp - During linking, specify the library file located at
/usr/local/lib/libaidgen.so - All interfaces are under the
aplux::aidgennamespace - AidGen 2.x unifies LLM text generation, multimodal inference, and embedding vectorization capabilities under a consistent API style and programming model
- Compared to version 1.x, 2.x integrates
aidllmandaidmlmfunctionality into the unifiedaidgennamespace, providing a Context → Tokenizer / EmbeddingExtractor / Generator layered architecture
Log Level.enum LogLevel
AidGen-SDK provides an API for setting the log level. You need to specify which log level to use with this log-level enum.
| Member Name | Type | Value | Description |
| INFO | uint8_t | 0 | Informational message |
| WARNING | uint8_t | 1 | Warning |
| ERROR | uint8_t | 2 | Error |
| FATAL | uint8_t | 3 | Fatal error |
Error Code.enum ErrorCode
AidGen-SDK 2.x interface methods uniformly return ErrorCode enum values. Developers can determine whether operations succeeded and locate issues based on the returned error codes.
| SUCCESS | int32_t | 0 | Operation succeeded |
| INVALID_PARAM | int32_t | -1 | Invalid parameter |
| NOT_INITIALIZED | int32_t | -2 | Not yet initialized |
| ALREADY_INITIALIZED | int32_t | -3 | Already initialized |
| OUT_OF_MEMORY | int32_t | -4 | Out of memory |
| UNSUPPORTED | int32_t | -5 | Unsupported operation |
| ABORTED | int32_t | -6 | Operation aborted |
| FILE_NOT_FOUND | int32_t | -10 | File does not exist or invalid path |
| FILE_OPEN_FAILED | int32_t | -11 | File cannot be opened (permission denied or locked) |
| FILE_EMPTY | int32_t | -12 | File exists but has no content |
| FILE_READ_ERROR | int32_t | -13 | I/O truncation or system-level error during file read |
| FILE_PARSE_ERROR | int32_t | -14 | File content JSON parsing failed |
| BACKEND_ERROR | int32_t | -20 | Generic runtime error thrown by the backend |
| BACKEND_NOT_FOUND | int32_t | -21 | Backend dynamic library not found |
| INTERNAL_ERROR | int32_t | -99 | Unknown exception or system-level crash fallback |
Backend Type.enum BackendType
For AidGen-SDK 2.x, different inference backend frameworks are supported to implement LLM inference tasks. The available inference backends are listed below.
| DEFAULT | uint8_t | 0 | Auto-select (priority: QNN248 > QNN240 > QNN236) |
| QNN236 | uint8_t | 1 | Qualcomm QNN SDK 2.36 inference backend |
| QNN240 | uint8_t | 2 | Qualcomm QNN SDK 2.40 inference backend |
| QNN248 | uint8_t | 3 | Qualcomm QNN SDK 2.48 inference backend |
Generation State.enum GenState
During inference, the Generator continuously returns generation results to the developer via callback functions. The GenState enum identifies the stage of each callback event, allowing developers to determine generation progress.
| IDLE | uint8_t | 0 | Idle, waiting for a new generation round |
| BEGIN | uint8_t | 1 | First token fragment of a sentence |
| CONTINUE | uint8_t | 2 | Middle continuation fragment of a sentence |
| END | uint8_t | 3 | End of sentence |
| ABORT | uint8_t | 4 | User interruption or task voluntarily abandoned |
| ERROR | uint8_t | 5 | System or hardware-level error |
Global Functions
Get Library Version.get_library_version()
Gets the version string of the current AidGen library.
| API | get_library_version |
| Description | Gets the version information of the AidGen library |
| Parameters | void |
| Return Value | A string containing the library version, e.g. "2.3.0" |
printf("Current aidgen library version: %s\n", version.c_str());Get ABI Version.get_abi_version()
Gets the ABI version number for binary compatibility detection.
| API | get_abi_version |
| Description | Gets the ABI version number of the AidGen library |
| Parameters | void |
| Return Value | ABI version number (unsigned 64-bit integer) |
printf("ABI version: %lu\n", abi_ver);Set Log Level.set_log_level()
Sets the minimum log output level for AidGen. Logs below this level will not be output.
| API | set_log_level |
| Description | Sets the minimum log output level |
| Parameters | log_level: LogLevel enum value specifying the minimum log level |
| Return Value | void |
aplux::aidgen::set_log_level(aplux::aidgen::LogLevel::ERROR);Set Log File Prefix.set_log_file_prefix()
Sets the log file path prefix. The library automatically appends suffixes to generate the actual log file and returns the final full path.
| API | set_log_file_prefix |
| Description | Sets the log file path prefix |
| Parameters | log_file_prefix: Log file prefix string (must not be empty) |
| Return Value | The final full log file path generated |
printf("Log file path: %s\n", log_path.c_str());Context Properties.struct ContextProperties
The ContextProperties struct is used to configure the behavior attributes of the Context, passed when creating a Context instance.
Member List
| Member Name | Type | Default Value | Description |
| stream | bool | true | Whether to enable streaming output |
| enable_profiler | bool | false | Whether to enable the profiler |
| enable_prompt_cache | bool | true | Whether to enable Prompt Cache acceleration |
Tensor.struct Tensor
The Tensor struct holds a data buffer and its size. It serves as the output container for EmbeddingExtractor and the input container for Generator's multimodal mode. By default, the deleter is nullptr, meaning the unique_ptr automatically calls delete[] to free memory upon destruction. Users can also provide a custom deleter (e.g., std::free) to manage externally allocated memory.
Member List
| data | std::unique_ptr<uint8_t[], TensorDeleter> | Data buffer pointer with support for custom deallocation functions | |
| size | size_t | 0 | Data size in bytes |
Generation Event.struct GenEvent
The data structure returned by the Generator through callback functions during inference, containing the current generation state and text content.
Member List
| state | GenState | Current generation state code | |
| text | std::string | Text fragment from this callback |
Meaning of text under each state:
| state | Meaning | text Content |
| IDLE | Not yet started | Empty |
| BEGIN | First token | First generated text |
| CONTINUE | Intermediate continuation | Continued generated text |
| END | Generation complete | Final text |
| ABORT | Interrupted | Partially generated text before interruption |
| ERROR | Error occurred | May be empty |
Generation Callback Type.GenCallback
Callback function type definition used during Generator inference. Developers need to implement this callback function type to process inference results.
using GenCallback = std::function<void(const GenEvent& event, void* user_data)>;⚠️Warning
It is strictly prohibited to call Generator::abort() inside the callback function, as this may cause deadlocks or undefined behavior.
Extractor Profile Data.struct ExtractorProfileData
Performance metrics collected by EmbeddingExtractor during inference.
Member List
| init_time_us | uint64_t | 0 | Initialization time (microseconds) |
| prompt_token_count | uint64_t | 0 | Prompt token count |
| execute_time_us | uint64_t | 0 | Inference execution time (microseconds) |
| prompt_processing_tps | float | 0.f | Prompt processing throughput (tokens/s) |
Generator Profile Data.struct GeneratorProfileData
Performance metrics collected by Generator during inference.
Member List
| time_to_first_token_time_us | uint64_t | 0 | Time to first token latency (microseconds) |
| generated_token_count | uint64_t | 0 | Generated token count |
| generate_time_us | uint64_t | 0 | Generation phase duration (microseconds) |
| generate_tps | float | 0.f | Generation throughput (tokens/s) |
Profile Data.struct ProfileData
Aggregates performance data from both the EmbeddingExtractor and Generator stages.
Member List
| extractor | ExtractorProfileData | Embedding extractor performance data | |
| generator | GeneratorProfileData | LLM generator performance data |
Runtime Context Class.class Context
Context is the inference context class that holds model configuration and backend settings, shared by Tokenizer, EmbeddingExtractor, and Generator. Context uses a global singleton pattern — only one Context instance is permitted at a time. Its lifecycle is: create_instance() → initialize() → use → automatic cleanup on destruction. Context is non-copyable and non-movable.
Create Instance Object.create_instance()
Creates the singleton Context instance. If an instance already exists, returns nullptr.
| API | create_instance |
| Description | Creates a Context singleton instance; only one is allowed at a time |
| Parameters | config: Model configuration file path (JSON), or the JSON content string itself (auto-detected by first non-whitespace character: `{` or `[` means JSON content, otherwise treated as a file path) |
| properties: ContextProperties struct reference, configuring streaming output, profiling, Prompt Cache, etc. | |
| backend_type: BackendType enum value specifying the inference backend, default BackendType::DEFAULT (auto-selects the best available backend) | |
| Return Value | If nullptr, an instance already exists or construction failed; otherwise, a shared_ptr to the Context object |
// Create context properties
props.stream = false;
props.enable_profiler = true;
// Create a Context instance
if(ctx_ptr == nullptr){
}Initialize Operation.initialize()
Performs the complete initialization flow: license validation → search and load backend plugin → parse model configuration JSON → verify backend version compatibility (major version + ABI + minimum minor/patch) → initialize backend handle.
| API | initialize |
| Description | Performs complete initialization including license validation, backend loading, and config parsing |
| Parameters | reserve: Reserved field, default value is nullptr |
| Return Value | ErrorCode::SUCCESS indicates success. May return BACKEND_NOT_FOUND, FILE_OPEN_FAILED, FILE_EMPTY, FILE_READ_ERROR, FILE_PARSE_ERROR, NOT_INITIALIZED, etc. |
💡Tip
If initialization reports Required QNN backend not found (error code BACKEND_NOT_FOUND), the corresponding QNN inference backend SDK is missing from the system. Install the appropriate backend package based on your model and target platform, for example:
aidgen-qnn236— for Qualcomm QNN SDK 2.36aidgen-qnn240— for Qualcomm QNN SDK 2.40aidgen-qnn248— for Qualcomm QNN SDK 2.48
After installation, ensure the backend dynamic library (e.g., libaidgen_qnn240.so) is located under /usr/local/lib.
// Initialize Context; non-SUCCESS return indicates an error
}Get Config.get_config()
Queries all configurable parameters under the backend's "context" scope. Must be called after initialize().
| API | get_config |
| Description | Queries all context-level configurable parameters from the backend |
| Parameters | void |
| Return Value | A string containing all context configuration parameters. Returns an empty string if not initialized |
printf("Context config: %s\n", config.c_str());Set Config.set_config()
Sets the value of a specified configuration item via the backend's "context" scope. Must be called after initialize(), and only effective before Tokenizer, Generator, or EmbeddingExtractor instances are created.
| API | set_config |
| Description | Sets a specified context-level configuration item value |
| Parameters | key: Configuration item key name |
| value: Configuration value | |
| Return Value | ErrorCode::SUCCESS indicates success. NOT_INITIALIZED if not initialized |
}Tokenizer Class.class Tokenizer
Tokenizer is a text tokenizer responsible for bidirectional conversion between text and token IDs. It uses a global singleton pattern — only one instance is allowed at a time. Its lifecycle is: create_instance() → initialize() → encode() / decode() → finalize() → destruction. Tokenizer is non-copyable and non-movable.
| Description | Creates a Tokenizer singleton instance; only one is allowed at a time |
| Parameters | context: std::shared_ptr<Context>, a shared initialized Context object (must not be nullptr) |
| reserve: Reserved field, default value is nullptr | |
| Return Value | If nullptr, the context is null, an instance already exists, or construction failed; otherwise, a unique_ptr to the Tokenizer object |
if(tokenizer_ptr == nullptr){
Initializes the tokenizer backend, loading the tokenizer model with the "NoEmbedding" target (vocabulary only, without embedding weights).
| API | initialize |
| Description | Initializes the tokenizer backend and loads the vocabulary model |
| Return Value | ErrorCode::SUCCESS indicates success |
}Encode Text to Token.encode()
Encodes a plain text string into a token ID sequence. Must call initialize() first.
| API | encode |
| Description | Encodes a text string into a token ID sequence |
| Parameters | text: Input text string to be encoded |
| token_ids: std::vector<int32_t>&, output token ID sequence | |
printf("Token count: %zu\n", token_ids.size());Decode Token to Text.decode()
Decodes a token ID sequence back into human-readable text. Must call initialize() first.
| API | decode |
| Description | Decodes a token ID sequence into a text string |
| Parameters | token_ids: Input token ID sequence |
| text: std::string&, output decoded text | |
std::string decoded_text;
printf("Decoded: %s\n", decoded_text.c_str());Finalize Release Operation.finalize()
Releases tokenizer backend resources. Must call initialize() first.
| API | finalize |
| Description | Releases tokenizer backend resources |
}Embedding Extractor Class.class EmbeddingExtractor
EmbeddingExtractor is used to encode text into a single embedding tensor, suitable for Retrieval-Augmented Generation (RAG), text semantic similarity computation, feature extraction, and other scenarios. It uses a global singleton pattern — only one instance is allowed at a time. Its lifecycle is: create_instance() → initialize() → encode() / get_profiler() → finalize() → destruction. EmbeddingExtractor is non-copyable and non-movable.
| Description | Creates an EmbeddingExtractor singleton instance; only one is allowed at a time |
| Return Value | If nullptr, the context is null, an instance already exists, or construction failed; otherwise, a unique_ptr to the EmbeddingExtractor object |
if(extractor_ptr == nullptr){
Initializes the embedding extractor backend and loads the embedding model. Must be called after Context::initialize().
| API | initialize |
| Description | Initializes the extractor backend and loads the embedding model |
}Finalize Release Operation.finalize()
Releases embedding extractor backend resources. Must call initialize() first.
| API | finalize |
| Description | Releases embedding extractor backend resources |
Get Property.get_property()
Queries all configurable parameters under the backend's "extractor" scope. Must call initialize() first.
| API | get_property |
| Description | Queries all configurable parameters under the extractor scope |
| Parameters | void |
| Return Value | Property value string. Returns an empty string if not initialized |
Set Property.set_property()
Sets a specified property value via the backend's "extractor" scope. Must call initialize() first.
| API | set_property |
| Description | Sets a specified property value under the extractor scope |
| Parameters | key: Property key name |
| value: Property value | |
Encode to Embedding.encode()
Encodes a text string into an embedding tensor. Must call initialize() first.
| API | encode |
| Description | Encodes text into an embedding tensor |
| Parameters | prompt: Input text string to be encoded |
| embedding: Tensor&, output embedding tensor (data and size are populated by the backend) | |
printf("Embedding size: %zu bytes\n", embedding.size);Get Profiler.get_profiler()
Retrieves performance profiling data from the last embedding extraction run, only filling the ProfileData::extractor field. Must call initialize() first.
| API | get_profiler |
| Description | Retrieves performance data from the last embedding extraction |
| Parameters | profile_data: ProfileData&, output performance data (only the extractor field is filled) |
}Generator Class.class Generator
Generator is an LLM token generator that supports both text-only and multimodal (embedding input) inference modes. It uses a global singleton pattern — only one instance is allowed at a time. Consecutive calls to run() are treated as multi-turn conversations, with internal automatic KV Cache reuse for acceleration; call reset() to clear historical cache and start a fresh conversation. Its lifecycle is: create_instance() → initialize() → run() / reset() / abort() / get_profiler() / get_state() → finalize() → destruction. Generator is non-copyable and non-movable.
| Description | Creates a Generator singleton instance; only one is allowed at a time |
| Return Value | If nullptr, the context is null, an instance already exists, or construction failed; otherwise, a unique_ptr to the Generator object |
if(generator_ptr == nullptr){
Initializes the generator backend and loads the language model. Must be called after Context::initialize().
| API | initialize |
| Description | Initializes the generator backend and loads the language model |
Releases generator backend resources. Must call initialize() first.
| API | finalize |
| Description | Releases generator backend resources |
Queries all configurable parameters under the backend's "generator" scope. Must call initialize() first.
| Description | Queries all configurable parameters under the generator scope |
| Parameters | void |
Sets generation parameters via the backend's "generator" scope. Must call initialize() first. Common properties include: "stream" (value "0" or "1", controls streaming output), and sampling parameters "temp", "top-k", "top-p" (all values in string format).
| Description | Sets a specified property value under the generator scope |
| Parameters | key: Property key name (e.g. "stream", "temp", "top-k", "top-p") |
| value: Property value (string format) | |
// Set sampling parameters
generator_ptr->set_property("top-p", "0.9");Get Embedding Buffer.get_embedding_buff()
Retrieves the raw pointer and size of the model's token embedding weight lookup table. Must call initialize() first.
The returned buffer stores all token embedding vectors contiguously in row-major order. Each token's embedding occupies embedding_size * sizeof(float) bytes. The embedding for the i-th token is located at offset i * embedding_size * sizeof(float). The pointer remains valid for the lifetime of the Generator instance — callers must NOT free this buffer.
Typical use case: manually constructing combined text + vision embedding tensors for multimodal inference.
| API | get_embedding_buff |
| Description | Retrieves the pointer and size of the model's token embedding weight buffer |
| Parameters | out_ptr: const char*&, output parameter receiving the pointer to the embedding weight buffer; set to nullptr on failure |
| out_size: size_t&, output parameter receiving the total size (in bytes) of the weight buffer | |
}Text-Only Inference.run()
Starts text-only inference based on a full prompt string. Consecutive calls to run() are treated as multi-turn conversations, with internal automatic KV Cache reuse for acceleration. Call reset() to start a fresh conversation.
⚠️Warning
It is strictly prohibited to call abort() inside the callback function, as this may cause deadlocks or undefined behavior.
| API | run |
| Description | Starts text-only inference based on a full prompt string (caller is responsible for chat template assembly) |
| Parameters | prompt: Complete prompt string; the developer is responsible for assembling system/user/assistant role markers |
| cb: GenCallback type callback function, triggered token-by-token as fragments | |
| user_data: Pointer to user-defined data, passed through to the callback function; default value is nullptr | |
// Define the callback function
switch(event.state){
break;
fflush(stdout);
break;
break;
break;
break;
default: break;
// Execute text-only inference
"<|im_start|>user\nHello<|im_end|>\n"
"<|im_start|>assistant\n";
}Multimodal Inference.run()
Starts multimodal inference based on a pre-computed embedding tensor. The developer is responsible for generating and assembling text embeddings and image embeddings. Consecutive calls to run() also reuse KV Cache; call reset() to clear.
⚠️Warning
| API | run |
| Description | Starts multimodal inference based on a pre-computed embedding tensor |
| Parameters | embedding: Tensor&, the embedding tensor (caller is responsible for generation and assembly) |
| cb: GenCallback type callback function | |
Reset Conversation State.reset()
Resets the internal KV Cache and conversation state via the backend's "generator_reset" action. Must be called after initialize(). Call this before starting a new topic in multi-turn conversations; after calling, previous KV Cache acceleration becomes invalid.
| API | reset |
| Description | Resets KV Cache and conversation state, preparing for a new conversation round |
// Reset before starting a new topic
// A fresh conversation can now begin
generator_ptr->run(new_prompt, dialog_callback);Abort Inference.abort()
Actively terminates the current inference task via the backend's "generator_abort" action. Must be called after initialize(). Typically called from another thread or triggered via a timeout mechanism.
⚠️Warning
It is strictly prohibited to call abort() inside the GenCallback callback function.
| API | abort |
| Description | Actively terminates the currently running inference task |
// Terminate inference from another thread
}Get Profiler.get_profiler()
Retrieves performance profiling data from the last inference run, only filling the ProfileData::generator field. Must call initialize() first.
| Description | Retrieves performance data from the last generation inference |
| Parameters | profile_data: ProfileData&, output performance data (only the generator field is filled) |
printf("Time to first token: %lu us\n", perf.generator.time_to_first_token_time_us);
printf("Generate rate: %.2f tok/s\n", perf.generator.generate_tps);
printf("Generated token count: %lu\n", perf.generator.generated_token_count);
}Get Current State.get_state()
Queries the current state of the generator (IDLE / BEGIN / CONTINUE / END / ABORT / ERROR). Must be called after initialize().
| API | get_state |
| Description | Queries the current running state of the generator |
| Parameters | state: GenState&, output parameter receiving the current state value |
| Return Value | Always returns ErrorCode::SUCCESS when initialized. NOT_INITIALIZED if not initialized |
}Typical Usage Flow
Complete Text-Only Inference Flow
→ Context::initialize()
→ [Optional] Generator::reset() → Generator::run(new_prompt, callback)
→ Generator::finalize()Complete example code:
#include "aidgen.hpp"
int main() {
// 1. Create Context and initialize
// 2. Create and initialize Generator
// 3. Execute inference
"<|im_start|>user\nHello, introduce yourself<|im_end|>\n"
fflush(stdout);
// 4. Get performance data and release
ProfileData perf;
generator->finalize();
}Tokenizer Usage Flow
→ Tokenizer::encode(text, token_ids) // Text → Token
→ Tokenizer::decode(token_ids, text) // Token → Text
→ Tokenizer::finalize()auto tokenizer = Tokenizer::create_instance(ctx);
tokenizer->initialize();
// Encoding
std::vector<int32_t> tokens;
// Decoding
std::string decoded;
tokenizer->finalize();Embedding Extraction Flow
→ EmbeddingExtractor::finalize()#include "aidgen.hpp"
int main() {
Tensor embedding;
ProfileData perf;
// Save embedding to file
}Error Handling Pattern
All methods returning ErrorCode should have their return values checked:
}Common initialization failure scenarios:
BACKEND_NOT_FOUND: QNN inference backend not found. Install the corresponding backend SDK (e.g.,aidgen-qnn240). See the tip underContext::initialize()above for details.FILE_OPEN_FAILED: Invalid model config file path or insufficient permissionsFILE_PARSE_ERROR: Model config file has malformed JSONNOT_INITIALIZED: Version incompatibility or license validation failure
Memory Management Principles
| Object | Management | Description |
| Context | shared_ptr | Shared ownership; should be destroyed after Generator / Tokenizer / EmbeddingExtractor |
| Generator | unique_ptr | Exclusive ownership; destructor automatically releases the singleton lock |
| Tokenizer | unique_ptr | Exclusive ownership; destructor automatically releases the singleton lock |
| EmbeddingExtractor | unique_ptr | Exclusive ownership; destructor automatically releases the singleton lock |
| Tensor::data | unique_ptr + custom deleter | Default delete[]; can pass std::free or other custom deleters |
AidGen 1.x C++ API Documentation (Deprecated)
⚠️Warning
The following is the AidGen 1.x API documentation, covering the aplux::aidllm and aplux::aidmlm namespaces. This version is no longer maintained. New projects should use the AidGen 2.x API above.
AidLLM C++ API Documentation
Before developing with AidGen-SDK C++, please be aware of the following basics:
/usr/local/include/aidlux/aidgen/aidllm.hpp - During linking, specify the library file located at
aplux::aidllmnamespace
Inference Backend Type.enum LLmBackendType
For AidllmSDK, different inference backend frameworks are supported to implement LLM inference tasks. The available inference backends are listed below.
| TYPE_DEFAULT | uint8_t | 0 | Unknown backend type |
| TYPE_GENIE | uint8_t | 1 | Genie inference backend |
Inference Task State.enum LLMSentenceState
During an inference task, a single session may go through multiple stages. Developers can use these state codes to understand the current runtime status of the inference task.
| BEGIN | enum class | 0 | Session start segment |
| CONTINUE | enum class | 1 | Intermediate content during ongoing session inference |
| END | enum class | 2 | Session ending segment |
| COMPLETE | enum class | 3 | Current session completed successfully |
| ABORT | enum class | 4 | Current session terminated passively |
| ERROR | enum class | 5 | Current session inference error |
Interpreter Runtime State.enum LLMState
The overall state of the Aidllm interpreter during runtime. Developers can query this state to understand the interpreter's current working status.
| STANDIDLE | enum class | 0 | Idle standby state |
| BUSYING | enum class | 1 | Busy processing inference |
| ABORT | enum class | 2 | Inference has been terminated |
| ERROR | enum class | 3 | Inference encountered an error |
AidllmSDK provides an API for logging (introduced later). You need to specify which log level is currently used, so this log-level enum is required.
| INFO | uint8_t | 0 | Message |
Global Functions
Gets the version information string of the current Aidllm library.
| Description | Gets the version information of the Aidllm library |
| Parameters | void |
| Return Value | A string containing the library version information |
printf("Current aidllm library version: %s\n", version.c_str());Set Log Level.set_log_level()
Sets the minimum log output level for Aidllm. Logs below this level will not be output.
aplux::aidllm::set_log_level(aplux::aidllm::LogLevel::ERROR);Set Log File Prefix.set_log_file_prefix()
Sets the log file name prefix for outputting logs to files with the specified prefix.
| Description | Sets the log file name prefix |
| Parameters | log_file_prefix: Log file name prefix string |
aplux::aidllm::set_log_file_prefix("aidllm_log_");Inference Callback Function Type.LLMCallback
The callback function type definition used during Aidllm inference. Developers need to implement a callback function of this type to handle inference results.
using LLMCallback = std::function<int32_t(LLMCallbackData& cb_data, void* user_data)>;💡Note
The callback function return type is int32_t. Returning 0 indicates normal continuation of inference; a non-zero value can be used to control the inference flow.
Inference Callback Data Type.struct LLMCallbackData
During inference tasks, Aidllm uses developer-provided callback functions. This data type is the argument passed to that callback function, and developers can use it in custom callbacks to process inference results.
Member List
The LLMCallbackData struct contains the following members:
| Member | state |
| Type | enum LLMSentenceState |
| Default Value | |
| Description | Status code of the current inference session |
| Member | text |
| Type | std::string |
| Default Value | |
| Description | Result text of the inference task / message corresponding to special status codes |
Runtime Context Class.class LLMContext
During Aidllm runtime, some configuration information may need to be set, and runtime-related data also needs to be passed around. Objects of this runtime context type are used to complete data flow.
To set runtime context information, you first need a configuration instance object. This function is used to create an instance object of type LLMContext.
| Description | Used to construct an instance object of class LLMContext |
| Parameters | config_file: Initial configuration file, where key information such as backend type and model file names can be configured |
| Return Value | If it is nullptr, object construction failed; otherwise, it is a pointer to an LLMContext object |
// Create a configuration instance object; report an error if the return value is null
}Member List
The LLMContext object is used to manage runtime configuration information, including the following parameters:
| Member | config_file |
| Default Value | |
| Description | Initial configuration file, the config file parameter passed when creating the object |
| Member | backend_type |
| Type | LLmBackendType |
| Default Value | LLmBackendType::TYPE_DEFAULT |
| Description | The developer is required to specify the inference backend in the config file. After initialization parses the config file, this field will be overwritten to indicate the backend type specified by the developer |
| Member | model_file_vec |
| Type | std::vector<std::string> |
| Default Value | |
| Description | The developer is required to specify model files in the config file. After initialization parses the config file, this field will be overwritten to indicate the model files specified by the developer |
| Member | config_overwrite_options |
| Default Value | |
| Description | By setting this field, you can specify certain key parameters in the inference process, thereby affecting inference speed, inference results, etc. |
| Member | android_tmp_directory |
| Default Value | |
| Description | This field is only valid on the Android platform. By setting this field, you can specify a directory for which the system user has valid permissions, for temporary use by the inference program |
Interpreter Class.class LLMInterpreter
An object instance of type LLMInterpreter is the main executor of inference operations and is used to carry out specific inference processes.
To perform inference-related operations, an inference interpreter is essential. This function is used to construct an instance object of the inference interpreter.
| Description | Uses various data managed by the LLMContext object to construct an object of type LLMInterpreter |
| Parameters | llm_context: Reference to the unique_ptr of an LLMContext instance object (std::unique_ptr<LLMContext>&) |
| Return Value | If it is nullptr, object construction failed; otherwise, it is a unique_ptr to an LLMInterpreter object |
// Use the LLMContext object pointer to create the interpreter object; report an error if the return value is null
}Initialization Operation.initialize()
After the interpreter object is created, some initialization operations are required, such as environment checks and resource construction.
| API | initialize |
| Description | Completes the initialization work required for inference |
| Parameters | enable_profiler: Whether to enable the profiler, default value is false |
| Return Value | A value of 0 indicates successful initialization; otherwise a non-zero value indicates failure |
// Initialize the interpreter; report an error if the return value is non-zero
}Sampling Parameter Setup Operation.set_sampler()
After initialization completes successfully, sampling parameters can be set with this function to control the randomness, diversity, and quality of generated content.
| API | set_sampler |
| Description | Sets sampling parameters to control the randomness and diversity of LLM outputs. |
| Parameters | key: Name of the sampling parameter. Currently supported:
value: Parameter value represented as a string:
| Return Value | A value of 0 indicates success; a non-zero value indicates failure (e.g. invalid key or unsupported value format). |
llm_interpreter_ptr->set_sampler("top-p", "0.9");Session Inference Operation.run()
After successful initialization, you can run dialog inference with the LLM. Developers provide a custom callback function to handle continuous inference results during the session.
| API | run |
| Description | Executes one session inference |
| Parameters | prompt: Prompt string |
| cb: Callback function of type LLMCallback for handling continuous inference results during the session | |
| user_data: Pointer to user data, convenient for using this data in custom callback functions, default value is nullptr | |
| Return Value | A value of 0 indicates the inference executed successfully; otherwise a non-zero value indicates failure |
// Define callback function
fflush(stdout);
return EXIT_SUCCESS;
// Execute inference
std::string prompt = "<|im_start|>user\nHello<|im_end|>\n<|im_start|>assistant\n";
}Query Inference State.state()
During inference, developers may need to query the current runtime state of the interpreter, such as determining whether it is idle or actively inferring.
| API | state |
| Description | Gets the current runtime state of the inference task |
| Parameters | state: Reference to an LLMState variable; the function will overwrite this variable with the current state |
| Return Value | A value of 0 indicates the query executed successfully; otherwise a non-zero value indicates failure |
printf("Current state: %d\n", (int)current_state);Session Termination Operation.abort()
In some situations, users may want to interrupt the session that is currently running inference. This function is used to terminate inference.
⚠️Warning
It is strictly forbidden to call the abort function inside the callback function (LLMCallback), as this may cause deadlocks or undefined behavior.
| API | abort |
| Description | Terminates the currently running inference session |
| Return Value | A value of 0 indicates successful termination; otherwise a non-zero value indicates failure |
// Terminate inference in another thread
}Final Release Operation.finalize()
As mentioned above, the interpreter object needs to run initialize() for initialization. Correspondingly, the interpreter also needs to run release operations to destroy previously created resources.
| API | finalize |
| Description | Completes necessary de-initialization and release operations |
| Return Value | A value of 0 indicates the release operation executed successfully; otherwise a non-zero value indicates failure |
// Execute interpreter de-initialization; report an error if the return value is non-zero
When the profiler is enabled during initialization (enable_profiler = true), this function can be used to obtain the profiler object pointer for performance data collection and analysis. For detailed usage, refer to the "Profiler C++ API Documentation" section below.
| Description | Gets the pointer to the profiler object |
| Parameters | void |
| Return Value | If the profiler is enabled, returns a Profiler object pointer; if not enabled, returns nullptr |
// Enable profiler during initialization
// Get the profiler
aplux::aidgen::Profiler* profiler = llm_interpreter_ptr->get_profiler();AidMLM C++ API Documentation
Before developing with AidMLM-SDK C++, please be aware of the following basics:
/usr/local/include/aidlux/aidgen/aidmlm.hpp - During linking, specify the library file located at
aplux::aidmlmnamespace - AidMLM is designed for multimodal large model (vision-language model) inference, currently supporting Qwen2-VL and Qwen2.5-VL series models
Inference State.enum AidLLMState
During an AidMLM inference task, a single session may go through various stages. Developers can use these state codes to understand the current runtime status of the inference task.
| STAND | enum class | 0 | Not yet working |
| START | enum class | 1 | Inference started |
| BUSYING | enum class | 2 | Inference in progress |
| FINISH | enum class | 3 | Inference finished |
| COMPLETE | enum class | 4 | Inference completed fully or truncated |
| WAITING | enum class | 5 | Current token decoding failed, waiting for next decode |
| ABORT | enum class | 6 | Current inference terminated early by developer |
| ERROR | enum class | 7 | Inference failed due to exception |
Model Type.enum ModelType
Specifies the type of multimodal model currently in use.
| RESERVED | enum class | 0 | Reserved type |
| QWEN2VL | enum class | 1 | Qwen2-VL model |
| QWEN25VL | enum class | 2 | Qwen2.5-VL model |
Inference Callback Data Type.struct AidLLMCBData
During AidMLM inference tasks, developer-provided callback functions are used. This data type is the argument passed to that callback function.
Member List
| Member | state |
| Type | enum AidLLMState |
| Default Value | |
| Member | text |
| Default Value | |
Inference Callback Function Type.AidLLMCB
The callback function type definition used during AidMLM inference.
using AidLLMCB = std::function<void(AidLLMCBData& cb_data, void* user_data)>;Image Data Type.struct ImageData
A struct for passing image data to the multimodal model.
Member List
| Member | img_pos |
| Type | int |
| Default Value | -1 |
| Description | Position index of the image in the prompt. If -1, the image is appended at the end of the prompt |
| Member | img_data |
| Type | uint8_t* |
| Default Value | nullptr |
| Description | Image data pointer, pointing to RGB format image pixel data. Developers need to pre-resize to the model's required width and height |
Initialization Parameter Type.struct AidmlmInitParam
Configuration parameters required for AidMLM initialization.
Member List
| vision_model_path | std::string | Vision encoder model file path | |
| pos_emb_cos_path | std::string | Position encoding cosine weight file path | |
| pos_emb_sin_path | std::string | Position encoding sine weight file path | |
| embedding_weights_path | std::string | Word embedding weights file path | |
| window_attention_mask_path | std::string | Window attention mask file path (Qwen2.5-VL only) | |
| full_attention_mask_path | std::string | Full attention mask file path (Qwen2.5-VL only) | |
| llm_model_path_vec | std::vector<std::string> | LLM model file path list | |
| dbg_opt | std::string | Debug options string | |
| type | ModelType | ModelType::RESERVED | Multimodal model type |
| qwen2vl_cfg | Qwen2VLConfig | Qwen2-VL model configuration | |
| qwen25vl_cfg | Qwen25VLConfig | Qwen2.5-VL model configuration | |
| genie_log_level | int | 1 | Genie backend log level (1=ERROR, 2=WARN, 3=INFO, 4=VERBOSE) |
| use_shared_buffer | bool | false | Whether to use shared buffer |
| use_mmap | bool | false | Whether to use memory-mapped model loading |
| use_genie_load_model_ex | bool | false | Whether to use Genie extended model loading |
Model Configuration Structs
AidMLM provides predefined model configuration structs to specify vision model configurations for different resolutions and parameter scales. Developers can choose the corresponding configuration based on the model in use.
| Config Struct Name | Model | Image Size | Embedding Dim |
| Qwen2VLConfig | Qwen2-VL | 644×644 | 1536 |
| Qwen25VLConfig | Qwen2.5-VL 3B | 392×392 | 2048 |
| Qwen25VL3B644Config | Qwen2.5-VL 3B | 644×644 | 2048 |
| Qwen25VL3B672Config | Qwen2.5-VL 3B | 672×672 | 2048 |
| Qwen25VL7B392Config | Qwen2.5-VL 7B | 392×392 | 3584 |
| Qwen25VL7B644Config | Qwen2.5-VL 7B | 644×644 | 3584 |
| Qwen25VL7B672Config | Qwen2.5-VL 7B | 672×672 | 3584 |
Global Functions
| Description | Gets the version information of the AidMLM library |
| Parameters | void |
printf("Current aidmlm library version: %s\n", version.c_str());Multimodal Inference Class.class Aidmlm
An object instance of type Aidmlm is the main executor of multimodal inference operations and is used to carry out vision-language model inference processes.
Construction and Destruction
Aidmlm objects are created via the default constructor.
aplux::aidmlm::Aidmlm mlm_ctx;Set Log Level.set_log_level()
A static method that sets the minimum log output level for AidMLM.
| Description | Sets the minimum log output level (static method) |
| Parameters | log_level: LogLevel enum value |
aplux::aidmlm::Aidmlm::set_log_level(aplux::aidmlm::LogLevel::INFO);Set Log File Prefix.set_log_file_prefix()
A static method that sets the log file name prefix.
| Description | Sets the log file name prefix (static method) |
| Parameters | log_file: Log file name prefix string |
aplux::aidmlm::Aidmlm::set_log_file_prefix("./test_mlm");Initialization Operation.initialize()
Loads the multimodal model and initializes the inference environment.
| API | initialize |
| Description | Loads the model and completes the initialization work required for inference |
| Parameters | param: AidmlmInitParam struct reference containing model paths, configurations, and other initialization parameters |
| enable_profiler: Whether to enable the profiler, default value is false | |
| API | set_sampler |
mlm_ctx.set_sampler("temp", "0.8");Session Inference Operation.run()
After successful initialization, you can send image-text combined prompts to the multimodal model for inference.
This function is not thread-safe. Only one thread can call the run method at a time.
| API | run |
| Description | Executes one multimodal session inference |
| Parameters | prompt: User prompt string |
| sys_prompt: System prompt string | |
| img_vec: Reference to an ImageData vector containing the image data to input | |
| cb: Callback function of type AidLLMCB for handling inference results | |
| starting_round: Whether this is the start of a new conversation round (true for new conversation start) | |
}else{
// Prepare image data (pre-resize to model-required dimensions, RGB format)
cv::Mat img_rgb;
cv::Mat img_resized;
.img_pos = -1,
img_vec.push_back(img_data);
std::string user_prompt = "Please describe the scene in this image";
if(run_result < 0){
}Session Termination Operation.abort()
Used to interrupt the currently running inference session.
| API | abort |
Reset Operation.reset()
In multi-round conversation scenarios, when you need to process the next image or restart a conversation, call reset to clear internal state.
| API | reset |
| Description | Resets the internal state of the inference engine to prepare for the next inference |
| Parameters | void |
| Return Value | A value of 0 indicates successful reset; otherwise a non-zero value indicates failure |
// Reset after processing one image, prepare for the next
if(mlm_ctx.reset() < 0){
Releases model resources and completes de-initialization.
| API | finalize |
| Description | Releases model resources and completes necessary de-initialization operations |
| Parameters | void |
| Return Value | A value of 0 indicates successful release; otherwise a non-zero value indicates failure |
if(mlm_ctx.finalize() < 0){
When the profiler is enabled during initialization, this function can be used to obtain the Profiler object pointer. For detailed usage, refer to the "Profiler C++ API Documentation" section below.
| Parameters | void |
// Enable profiler
// ... other parameter setup ...
// Get performance data after inference
printf("Init time: %lu us\n", data.init_time_us);
printf("Time to first token: %lu us\n", data.time_to_first_token_us);
printf("Generate rate: %.2f tok/s\n", data.generate_rate);
printf("ViT execute time: %lu us\n", data.vit_execute_time_us);Profiler C++ API Documentation
Profiler-related interfaces are under the aplux::aidgen namespace (independent of aplux::aidllm and aplux::aidmlm).
- Header file path
/usr/local/include/aidlux/aidgen/profiler.hpp - Both AidLLM and AidMLM use their respective
get_profiler()methods to obtain a Profiler object for performance analysis
Performance Data Type.struct ProfileData
During inference, developers may want to monitor performance metrics at each stage. The ProfileData struct stores performance data collected during the inference process.
Member List
| Member Name | Type | Description |
| init_time_us | uint64_t | Initialization time (microseconds) |
| prompt_token_num | uint64_t | Number of input prompt tokens |
| prompt_processing_rate | float | Prompt processing rate (tok/s) |
| time_to_first_token_us | uint64_t | Time to first token (microseconds) |
| generated_token_num | uint64_t | Number of generated tokens |
| generate_rate | float | Token generation rate (tok/s) |
| generate_time_us | uint64_t | Total generation time (microseconds) |
| vit_execute_time_us | uint64_t | Vision model execution time (microseconds), AidMLM only |
| vit_init_time_us | uint64_t | Vision model initialization time (microseconds), AidMLM only |
| vit_preprocess_time_us | uint64_t | Vision model preprocessing time (microseconds), AidMLM only |
| vit_postprocess_time_us | uint64_t | Vision model postprocessing time (microseconds), AidMLM only |
Profiler Class.class Profiler
The Profiler class manages performance data collection during inference. It must be enabled during initialization (enable_profiler = true) to be used.
Get Performance Data.get_data()
Gets the currently collected performance data.
| API | get_data |
| Description | Gets the performance analysis data collected during inference |
| Parameters | void |
| Return Value | ProfileData struct containing performance metrics for each stage |
Reset Performance Data.reset()
Resets the collected performance data, typically called before starting a new inference round.
| API | reset |
| Description | Clears collected performance data and restores to initial state |
| Parameters | void |
// Get the profiler
// Execute inference...
printf("Generated token count: %lu\n", data.generated_token_num);
// Reset data, prepare for next inference round
profiler->reset();
