Deploy VLM HTTP Server with AidGenSE
Introduction
Edge deployment of Vision Language Models (VLM) refers to the process of compressing, quantizing, and deploying large models originally run in the cloud onto local devices to enable offline, low-latency natural language understanding and generation. This chapter uses the AidGenSE inference engine as a base to demonstrate how to deploy a multi-modal large model HTTP service (compatible with the OpenAI API) on edge devices.
In this case, the multi-modal large model inference runs on the device side. Relevant interfaces are called via HTTP API to receive user input and return dialogue results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-VL-3B (392x392)
Supported Platforms
PlatformRunning Method
Preparation
  1. Rhino Pi-X1 hardware
Case Deployment
Step 1: Install AidGenSE
sudo aid-pkg -i aidgense
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
Step 2: Model Query & Acquisition
  • View supported models
# View supported models
aidllm remote-list api
#------------------------Example output is as follows------------------------
Current Soc : 8550
Name                                                    Url                                                           CreateTime
qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550    aplux/qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550    2026-05-15 10:57:51
qwen2.5-vl-3b-instruct-672x672-qnn2.36-w4a16-qcs8550    aplux/qwen2.5-vl-3b-instruct-672x672-qnn2.36-w4a16-qcs8550    2026-05-15 10:57:49
  • Download qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# Download the model
aidllm pull api aplux/qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# View downloaded models
aidllm list api
Step 3: Start the HTTP Service
# Start the openai api service for the corresponding model
aidllm start api -m qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# Check status
aidllm status api
# Stop service: aidllm stop api
# Restart service: aidllm restart api
The default port number is 8888.
Step 4: Dialogue Test
Dialogue Test Using Web UI
# Install the UI front-end service
sudo aidllm install ui
# Start the UI service
aidllm start ui
# Check UI service status: aidllm status ui
# Stop UI service: aidllm stop ui
After starting the UI service, access http://ip:51104.
Dialogue Test Using Python
import os
import sys
import requests
import json
import base64
def stream_chat_completion(messages, model="qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550"):
    headers = {
    payload = {
        "model": model,
        "messages": messages,
        "stream": True    # Enable streaming
    # Send request with stream=True
    try:
        response.raise_for_status()
    except requests.HTTPError as e:
        print(f"\nHTTP error: {e}", file=sys.stderr)
        if response.text:
            print(response.text, file=sys.stderr)
        raise
    # Read and parse SSE format line by line
        if not line:
            continue
        # print(line)
        # Each line of SSE starts with the "data: " prefix
            # End flag
            if data.strip() == "[DONE]":
                break
            try:
                chunk = json.loads(data)
            except json.JSONDecodeError:
                # Print and skip when parsing fails
                print("Failed to parse JSON:", data)
                continue
            # Extract the token output by the model
            if content:
def image_to_data_url(image_path):
    """Read an image and convert it to a data URL, compatible with the OpenAI-style image_url field."""
    ext = os.path.splitext(image_path)[1].lower()
    mime_map = {
        ".jpg": "image/jpeg",
        ".jpeg": "image/jpeg",
        ".png": "image/png",
        ".webp": "image/webp",
    mime_type = mime_map.get(ext, "image/jpeg")
    b64_str = image_to_base64(image_path)
    return f"data:{mime_type};base64,{b64_str}"
if __name__ == "__main__":
    image_url = image_to_data_url("/path/to/your/image.jpg")
    # Example dialogue
    messages = [
            "role": "system",
            "content": "You are a helpful assistant."
            "role": "user",
            "content":[
                            "type": "text",
                            "text": "Describe the content of this image."
                            "type": "image_url",
                            "image_url":
                                "url": image_url
    print("Assistant:", end=" ")
    print()  # New line
