TOF Sensor ​
Nooploop ​
Preparation ​
  • Rhino Pi-X1
  • Nooploop TOFSense Series TOF Sensor
  • CH340 (USB-to-TTL Adapter)
  • Several other connecting cables
Hardware Connection ​
  1. Identify the CH340 device:
ls -l /dev/ttyU*
  1. Make the connections:
  • Connect the CH340 adapter to any USB port of Rhino Pi-X1.
  • Connect TX, RX, VCC, and GND of the CH340 adapter to RX, TX, VCC, and GND of the sensor respectively.
Testing ​
After completing the connections, open the minicom tool in the AidLux terminal (install it first if not present using the command: sudo apt update;sudo apt install minicom).
Once installed, open the serial port:
sudo minicom -D /dev/ttyUSB0 -b 921600 -H
The default baud rate of the TOF sensor is 921600, and data needs to be displayed in hexadecimal format.
Note: If minicom only displays a single line of data, configure it as follows: Press CTRL-A Z to enter the minicom settings page, then press W to enable line wrapping for display.
Below is an example of the received data.
