常见问题
Q&A
Q: When viewing the model structure, the input shape contains question marks (?) or words like batchsize. How should I fill in the input shape?
A: When there is a ? in the input shape, the automatically filled input shape becomes 0, which may cause model conversion to fail. You can manually replace ? with 1. If errors still occur, you will need to modify the original model’s input shape. For example, if the ONNX model’s input shape is [?,3,224,224], use Python and the ONNX package to reload the model, change the input shape to [1,3,224,224], save it again as an ONNX model, and then convert it using AIMO.
Q: During model optimization, the process remains stuck in "converting" for a long time. Is it frozen or dead?
A: In the INT8 quantization options, different quantization methods and model sizes can significantly affect conversion time. If you select methods like ada_aimet, cle_aimet, or bc_snpe, the optimization process can take a very long time (possibly days). Be patient with ada_aimet and cle_aimet. If you want faster results, you can choose cle_snpe, enable_htp, or enable_hta as quantization methods.
Error Log
| No. | Description | |
| 1 | ERROR : [AIMET] Optimization is failed. Please consider disable ada or cle. | AIMET does not support the selected method (cle_aimet or ada_aimet). Try using a different method. |
| 2 | ERROR : ValueError: After pruning disconnected nodes, this model is empty. Encountered Error: After pruning disconnected nodes, this model is empty. | Model issue: the model is empty and contains no valid nodes. Check the model and ensure it was uploaded correctly. |
| 3 | ERROR : [DLC-QUAN] [ERROR] Invalid model for HBA quantization algorithm. Ensure there were batchnorms present prior to initial conversion, or reconvert. | Caused by HTP quantization incompatibility with some model nodes. Avoid combining HTP with incompatible methods. Try HTP alone or combinations like HTP+CLE, CLE+BC, etc. |
| 4 | ERROR : Node XXXX: 'Graph has no buffer XXX, referred to as input for XXX' | Node in the model graph not found. |
| 5 | ERROR : Model conversion failed due to non-existent or rigid pid | AIMO service not started. |
| 6 | ERROR : ValueError: Unsupported dynamic weights on tensor permute_0_0 | Model has dynamic weights or dynamic input, which is unsupported. Consider truncating the model. |
| 7 | ERROR : Cutoff model is failed, please check nodes name | Input/output nodes or input shape values are incorrect. Check the model structure and fill in the correct values. |
| 8 | Conversion FAILED: ERROR_TF_NODE_NOT_FOUND_IN_GRAPH: Node not found in graph. Node name | Input/output nodes or input shape values are incorrect. Check the model structure and fill in the correct values. |
| 9 | status == QNN_BACKEND_NO_ERROR was not true | The selected chip does not support conversion for certain operators in the model. Try a different chip or use a generic conversion strategy. |
| 10 | AttributeError: 'UDOFactory' object has no attribute 'xxx' | The model includes unsupported operators. Identify their location in the model. If they are at the beginning or end, consider using input/output node truncation to skip them. You may also manually modify the unconverted part or report the missing operators to the backend for support. |
| 11 | [ERROR] 909 HTP FP16 not supported for this SoC | The quantization algorithm doesn't support this data format. Try disabling the CLE method. |
| 12 | While converting to RKNN, error occurs: onnx.onnx_cpp2py_export.checker.ValidationError: Your model ir_version is higher than the checker's** | The ONNX model version is too high. When exporting to ONNX, try setting opset to 12. |
| 13 | When converting ONNX to DLC, even with correct output nodes, error occurs: failed, please check nodes name:xxx input_name:xxx output_name:xxx | The ONNX model version is too high. When exporting to ONNX, try setting opset to 12. |
| 14 | During optimization: “SNPE HTP Offline Prepare: Could not assign any layer to the HTP” or “HTP FP16 not supported for this SoC” | To resolve this, try unchecking CLE or CLE+BC methods and use only the basic SNPE quantization method with HTP. |
