Browser Login ​
Prerequisites ​
  • Mainboard: Rhino Pi X1
  • Power supply: DC12V 5A power adapter
  • Input device: USB TYPE-A to TYPE-C cable
  • Communication device: Standard Ethernet cable
Start the Board ​
The board comes pre-installed with the Ubuntu 22.04 system. After powering it with a 12V power adapter, the board will start the system automatically.
  • Boot process: Power indicator red light stays on
  • Use a USB TYPE-A to TYPE-C cable: insert the TYPE-A port into the Windows computer's USB port, and the TYPE-C port into the board's C port.
  • System started successfully: The RGB light is solid green light stays on and the fan starts running, indicating the boot is complete
Obtain IP Address via ADB ​
Install ADB Software ​
Visit the link ADB Download and select the corresponding platform to download the ADB software.
Open Terminal in the ADB folder directory and enter adb. If ADB-related command descriptions are output, the environment is normal.
For more ADB usage, refer to Basic ADB Usage.
Obtain IP Address ​
# Access the device
# Obtain IP address
ifconfig eth0
The following output will be displayed:
The inet addr parameter indicates the device's IP address.
For more methods to obtain IP address, refer to IP Address Obtaining.
Log into the Web Page ​
After obtaining the device's IP address, you can log into the hybrid system's web interface using the following method:
  • Ensure the PC and the board are on the same local area network.
  • Enter the URL in the browser: http://ip:8000/login. Replace ip in the URL with the device's actual IP address. Username/Password: aidlux/aidlux
Use the System ​
After successfully starting the system, developers can officially use the Ubuntu 22.04 system on the Rhino-X1. For details, refer to System Usage
If developers need to reinstall the system or perform an OTA upgrade, refer to: System Burning
