ADB Login ​
Prerequisites ​
Developers need to prepare the following hardware devices in advance:
  • Mainboard: Rhino Pi X1
  • Power supply: DC12V 5A power adapter
  • Input device: USB TYPE-A to TYPE-C cable
ADB Software Installation ​
Visit the link ADB Download and select the corresponding platform to download the ADB software.
Open Terminal in the ADB folder directory and enter adb. If ADB-related command descriptions are output, the environment is normal.
ADB Command Output
Start the Board ​
The board comes pre-installed with the Ubuntu 22.04 system. After powering it with a 12V power adapter, the board will start the system automatically.
  • Boot process: Power indicator red light stays on
  • System started successfully: The RGB light is solid green light stays on and the fan starts running, indicating the boot is complete
Connect the Device ​
Use the USB TYPE-A to TYPE-C cable: insert the TYPE-A port into the Windows computer's USB port, and the TYPE-C port into the board's C port.
Access the System via ADB ​
After starting the board, developers can log into the Ubuntu system using the ADB tool with the following command:
For more ADB usage, refer to Basic ADB Usage.
Use the System ​
After successfully starting the system, developers can officially use the Ubuntu 22.04 system on the Rhino Pi-X1. For details, refer to System Usage
