AidVoice SDK
Introduction
The AidVoice SDK is an AI inference SDK specifically designed for voice-related models launched by Athinkra. It aims to simplify the development of core voice processing functions based on edge AI technology, allowing developers to integrate them flexibly and quickly into intelligent applications. The SDK provides a unified and efficient API, supporting industry-leading voice processing AI models to meet the requirements of various business scenarios.
Support Matrix
Operating System Support
LinuxAndroid
C++
Python🚧
Java
ASR Model Support
Whisper-Base-enSenseVoiceSmallWhisper Other Versions
TTS Model Support
MeloTTS-ChineseMeloTTS-English
✅: Supported 🚧: Planned
Quick Start
Installation
# Install AidLite QNN version 2.36
# Install AidVoice SDK
sudo aid-pkg -i aidvoice-sdk
To be released
Development Workflow
ASR
TTS
Examples
ASR: Identifying Audio Files in QCS8550 Linux System
Compile Test Code
# Copy test code
# Compile
cd /home/aidlux/aidvoice/asr/cpp/
mkdir -p build && cd build
cmake ..
make
Run Example
Tutorial
./test_asr
NOTE
The example uses Whisper by default. To switch to SenseVoiceSmall, please modify the code in test_asr.cpp from cfg.model_type = ModelType::TYPE_WHISPER; to cfg.model_type = ModelType::TYPE_SENSEVOICE;.
TTS: Text-to-Speech in QCS8550 Linux System
Compile Test Code
# Copy test code
# Compile
cmake ..
make
Run Example
./test_tts
The audio file will be generated in the current directory.
TIP
The example uses MeloTTS-English by default. To switch to MeloTTS-Chinese, please modify the following line in the test_tts.cpp code (Note: the original text incorrectly referred to test_asr.cpp): cfg.model_type = ModelType::TYPE_MELOTTS_ENGLISH; -> cfg.model_type = ModelType::TYPE_MELOTTS_CHINESE;
