Temperature and Humidity Sensors
Sonbus SM7820B
- Official Kit Documentation: Sonbus SM7820B
Preparation
- Rhino Pi-X1
- Sonbus SM7820B Temperature and Humidity Sensor
- USB-to-RS485 adapter board
- Several Dupont wires
Hardware Connection
Since the A8550PF1 has no directly exposed RS485 pins, a USB-to-RS485 adapter board is required for use.
- Identify the USB-to-RS485 device:
shellls -l /dev/ttyU*Connect A+ and B- of the USB-to-RS485 adapter board to pins A and B of the temperature sensor respectively.
Connect PIN2 and PIN6 (Raspberry Pi side) of Rhino Pi-X1 to the VCC and GND pins of the temperature and humidity sensor respectively.
Testing
The Sonbus temperature and humidity sensor requires a manual measurement command to be sent to return a reading—one command sent yields one result.
- Since the minicom testing tool cannot send hexadecimal data to control the sensor for measurement, a script can be written to convert the data format and send it to the serial port device. The script content is as follows:
#!/bin/bash
# Check the number of parameters
if [ "$#" -ne 2 ]; then
echo "Usage: $0 [Serial Port Device] [Hexadecimal Data]"
exit 1
fi
# Serial port device, e.g., /dev/ttyS2
SERIAL_PORT=$1
# Hexadecimal data, e.g., '1F2E3D4C'
HEX_DATA=$2
# Convert hexadecimal data to binary stream and send to the serial port
printf "$HEX_DATA" | xxd -r -p > $SERIAL_PORT- Send the control command using the script:
sudo ./send_hex.sh /dev/ttyHS1 '010300000002C40B'
./send_hex.sh /dev/ttyUSB0 '010300000002C40B'/dev/ttyHS1: RS485 device number of Rhino Pi-X1010300000002C40B: Command to read temperature and humidity measurement data. For other commands (e.g., baud rate modification), refer to the Sonbus product manual.
- Receive data using the minicom tool in AidLux (install it first if not present:
sudo apt update; apt install minicom).
Open minicom: sudo minicom -D /dev/ttyHS1 -b 9600 -H
sudo minicom -D /dev/ttyUSB0 -b 9600 -H/dev/ttyUSB0: Device number of the USB-to-RS485 adapter board-b 9600: Set the baud rate to 9600 (default baud rate of the sensor)-H: Display data in hexadecimal format
Result Analysis
After sending a query frame command to the temperature and humidity sensor, a response frame will be returned: 01 03 04 09 0d 16 8f 27 a8.
The response format is shown in the figure below:
Among the returned data, Data 1 represents temperature and Data 2 represents humidity. Using the calculation method provided in the Sonbus SM7820B manual (taking temperature calculation as an example):
- Convert the hexadecimal value
0a e4to decimal: 2317. - The data scaling factor is 100, so the actual temperature is calculated as 2317 / 100 = 23.17 °C, meaning the current indoor temperature is 23.17 °C.
