AidLux Full Package Installation ​
Reminder
Flashing will format the system, please back up your data in advance.
Flashing Tool Installation ​
When using the Rhino Pi, developers need to pre-install necessary software on their local Windows computer. The required software is as follows:
  • USB Driver: USB_Driver_qud.win.1.1_installer_10061.1.zip
  • System Flashing Tool: QPST_2.7.496.zip
  • ADB Tool: platform-tools.zip
Software download link: Software Tool Installation Package Download Link
USB Driver Installation ​
System Flashing Tool Installation ​
ADB Tool Installation ​
Full System Package Installation ​
ROM Package Download ​
Please visit the Android Image download link to download the full system package image for flashing.
Switching to Flashing Mode ​
  • After the device is powered on, use a USB Type-A to Type-C cable to connect the computer and the device. The Type-A end connects to the computer, and the Type-C end connects to the device.
  • After connecting, on the Windows computer, press WIN + R, type cmd, and execute adb devices in the opened window. Connected devices will be listed. If none are listed, wait a moment or unplug and re-plug the Type-C cable and execute the command again.
  • Switch to flashing mode by executing:
adb reboot edl
Configuring QFIL's Configuration Item ​
  • Open QFIL, and click on Configuration - FireHose Configuration at the top.
  • In the pop-up Download Configuration window, make the following settings:
Select 0-Sahara for Download Protocol
Select ufs for Device Type
Check the Reset After Download option
Ensure other options remain consistent with the screenshot below.
  • After configuration, click OK to save.
Selecting the Flashing Port ​
  • Click the Select Port option, and in the pop-up window, select the appearing 9008 port, then click OK.
  • After switching to flashing mode, the 9008 port should appear automatically in this window. If it does not appear, disconnect the power, restart, execute the switch command again, and wait for it to appear.
Selecting Build Type ​
  • Find the Select Build Type item and select Flat Build.
Selecting the Flashing File ​
  • Unzip the ROM file. We will use the "A8550BF1-100.T04_LA.user.2025111620.aidlux" version as an installation example.
  • Find the Select Programmer item, click Browse... next to Programmer Path, navigate to the unzipped path, and select the unzipped ROM file.
  • Change the file view suffix to All Files (*.*).
  • Select the xbl_s_devprg_ns.melf file and click Open.
Selecting the Flashing XML File ​
  • Find the Select Flat Build item, click Load XML... below it, and select the flashing XML file.
  • In the pop-up window, select All Files and click Open.
  • The interface will automatically pop up another window. Select All Files and click Open.
Starting the Flashing ​
  • Once all the above options are selected, click Download to start flashing.
  • Wait for approximately 5 minutes. When successfu appears, the flashing is complete. If flashing fails, please contact Aplux after-sales personnel.
  • After flashing is complete, the system will automatically reboot.
AidLux System Initialization ​
After installing the full system package, AidLux is pre-installed on the Android system, but the user needs to manually click the AidLux icon to initiate initialization. The system is ready to use once initialization is complete.
  • On the Android home screen, use the left mouse button to click and swipe up on the desktop to open the AidLux icon and start initialization.
  • When the system initialization progress reaches 100%, the system installation is complete.
