Hardware Information ​
System Block Diagram ​
Interface Description ​
Interface No.Interface NameFunction Description
140 PIN 3.3V GPIOSame pinout definition as Raspberry Pi 40 PIN
2/3/7Camera InterfaceMIPI CSI DPHY 4-lane interface, same definition as Raspberry Pi
4WIFI/BT AntennaWIFI/BT antenna interface, IPEX Gen 4
5Fan Interface5V fan driver interface
6EDL InterfaceForced download configuration interface (for emergency use only)
8RTC Battery InterfaceRTC battery interface
940 PIN 1.8V GPIO40 PIN 1.8V GPIO expansion interface
10QCS8550 Core BoardQCS8550 core board
11DC_INDevice power input, voltage range: 12V, typical value 12V@5A
12LINE OUTAudio output
13LINE INAudio input
14HDMI_OUTHDMI signal output, resolution/frame rate: 2K/120fps
15HDMI_INHDMI signal input, resolution/frame rate: 2K/30fps
16USB3.04-channel USB3.0 interface
17WANRJ45 Ethernet port for internet connection
18LANRJ45 Ethernet port
19LANRJ45 Ethernet port
20LANRJ45 Ethernet port
21TYPE-CUSB TYPE-C interface
22POWERPower button
23Volume +Volume up button
24Volume -Volume down button
25TF Card SlotMicro SD card slot
26M.2 InterfaceM.2 M Key 2280 interface
