Depth Camera ​
Warning
The device tests below are verified in the ROS2 environment. Please refer to the Tool Installation section to install all ROS-related tools.
Intel RealSense D415 ​
Preparation ​
  • Rhino Pi-X1
  • Intel RealSense D415 depth camera and corresponding drivers
Follow the steps below for installation: After installing Ubuntu Desktop and connecting via a VNC tool, execute the following commands in the terminal window:
sudo apt-get update
Hardware Connection ​
Connect the depth camera to the USB port of Rhino Pi-X1.
Testing ​
  1. After successful connection, launch the camera driver using the following command:
  1. Open RViz2 Open a terminal and enter: rviz2
  1. Verify and display the depth camera image in RViz2 Click the Add button in the bottom-left corner.
Click By topic in the pop-up window.
Double-click to open image under the /camera node, and observe the camera-captured image appearing in the image pop-up window in the bottom-left corner.
