Monitor Usage ​
Rhino-X1 supports one HDMI output port and one HDMI input port.
Hardware Connection ​
HDMI Output Port: The HDMI output port can be connected to a monitor, TV, or other HDMI input devices to display system images. It supports a maximum output of 1080P / 120FPS.
HDMI Input Port: The HDMI input port supports video input, with a maximum support of 4K / 30FPS.
Default Resolution ​
If ADB tools are not installed on your computer, refer to the document Basic Usage of ADB to install them.
After installation, on a Windows computer, press Win+R, enter cmd, and confirm to open a terminal window. Enter the following command in the window to check the current resolution:
adb shell wm size
The default resolution queried is: 1080 x 2340
