Screen Mirroring Login ​
Prerequisites ​
Developers need to prepare the following hardware devices in advance:
  • Mainboard: Rhino Pi-X1
  • Power Supply: DC 12V 5A power adapter
  • Input Devices: USB Type-A to Type-C cable
QtScrcpy Software Installation ​
Visit the QtScrcpy download address to download and install the corresponding platform package:
Starting the Board ​
The board comes pre-installed with the Android 13 system. After supplying power using the 12V power adapter, the board will automatically boot the system.
  • Boot-up Process: The power indicator light is solid red.
  • Use a USB Type-A to Type-C cable: Plug the Type-A end into the USB port of a Windows computer, and the Type-C end into the board's C port.
  • Normal system startup: The RGB light is solid red and the fan is running, indicating that the system has completed booting up.
Connecting the Device ​
Connect the board and the computer using the Type-C cable.
Accessing the System using Screen Mirroring Software ​
Open the QtScrcpy application. You should find the board device, double-click it to access the device screen.
Entering the AidLux system
Once the device screen is displayed, swipe up on the screen using the mouse to bring up the application menu. Click the AidLux application icon to enter the Ubuntu 22.04 system interface.
The Ubuntu 22.04 system interface of AidLux is as follows:
