AidStream Developer Documentation ​
AidStream SDK is a GStreamer-based real-time multimedia data processing toolkit for building AI-powered video and image analytics applications and services. It provides GStreamer plugins accelerated by hardware backends such as GPU, VPU, and NPU, allowing developers to build and deploy end-to-end multimedia AI applications more quickly, more simply, and with greater flexibility.
AidStream is a video framework for building streaming applications. Its goal is to simplify video-plus-AI application development, especially when custom algorithms need to be inserted into the processing flow.
AidStream uses a pipeline-oriented architecture. The pipeline elements are intentionally simple and are divided into input and output stages. After the pipeline starts, the SDK can obtain RGB data between the input and output stages through callback functions. Developers can process the RGB data inside the callback and return the processed frames to the pipeline, after which the frames continue through the downstream output stages.
Version 3 is a major upgrade over the original AidStream release.
The general AidStream workflow is shown below:
AidStream workflow
Hardware Performance ​
For detailed performance figures, see Hardware Performance Reference.
Supported Hardware Platforms and Operating Systems ​
SoC PlatformHardware ModelOperating SystemGStreamer Plugin Examples
QCS8550Rhino Pi X1 / MC940 / FV04Ubuntu 22.04Plugin Type I
QCS8625QCS8625Ubuntu 22.04Plugin Type I
QCS6490AGC6490 / Rhino Pi A1Ubuntu 22.04 / Ubuntu 24.04Plugin Type II
QCS6490Ruisha PiAidLux Fusion System (Ubuntu 22.04)Plugin Type III
How to Use This Guide ​
General examples are provided in two forms:
GStreamer Plugin Examples ​
Placeholder conventions used below:
  • <input-stream-url>: the input camera or streaming source address. Example: rtsp://admin:aidlux123@192.168.111.236:554/h264/ch1/main/av_stream
  • <output-stream-url>: the target streaming server address. Example: rtsp://admin:aidlux123@192.168.111.115:8554/test-111
After installing the AidStream-GST package, the corresponding model files are located in /usr/local/share/aidstream-gst/example/datas/. Make sure the required model files are present before running the examples.
The directory /usr/local/share/aidstream-gst/example/plugines/gst-plugin-customize is reserved for custom pre-processing and post-processing modules.
Plugin Type I ​
Plugin Type I Example Index ​
PlatformExample
QCS8550 / QCS86251. Object detection (YOLOv5)
2. Object detection (YOLOv8)
3. Segmentation (YOLOv8)
QCS8550 (FV04)4. H.264 pipeline
5. H.265 pipeline
6. 4-way mosaic composition
7. AI detection with overlay output
Example 1: YOLOv5 with the AidLite Toolchain ​
! qtivtransform engine=2 ! video/x-raw\(memory:GBM\),format=BGR \
AidStream YOLOv5 object detection demo
Example 2: YOLOv8 with the AidLite Toolchain ​
AidStream YOLOv8 object detection demo
Example 3: YOLOv8 Segmentation with the AidLite Toolchain ​
gst-launch-1.0 -e \
t. ! queue ! qtivcomposer name=mixer1 ! queue ! qtic2venc ! h264parse ! rtspclientsink protocols=tcp location=<output-stream-url> \
! mixer1.
AidStream YOLOv8 segmentation demo
The following examples are primarily intended for the FV04 hardware variant.
Example 4: H.264 Pipeline ​
gst-launch-1.0 rtspsrc location=<input-stream-url> \
! rtph264depay \
! h264parse \
! qtic2vdec \
! video/x-raw,format=RGB \
! qtic2venc \
! queue \
! h264parse \
Example 5: H.265 Pipeline ​
gst-launch-1.0 -e \
rtspsrc location=<input-stream-url> ! rtph265depay ! h265parse ! qtic2vdec ! \
queue ! tee name=split \
split. ! queue ! qtimlvconverter name=qmlconvert_1 ! qtimlqnn name=qtimlqnn_1 model=./640_yolov8s_qcs8550_w8a8.qnn228.aarch64.gcc9_4.so backend=/usr/lib/libQnnHtp.so ! \
video/x-raw\(memory:GBM\) ! capsfilter name=ml_capsfilter ! mixer1.
Example 6: 4-Way Mosaic Composition ​
<1920,1080> can be replaced with any other supported resolution, such as <3840,2160>.
! video/x-raw\(memory:GBM\),format=NV12,width=3840,height=2160 ! qtic2venc ! h264parse config-interval=1 ! rtspclientsink protocols=tcp location=<output-stream-url> \
rtspsrc location=<input-stream-url> latency=100 ! rtph264depay ! h264parse config-interval=-1 ! qtic2vdec ! qtivtransform engine=2 ! mixer. \
Example 7: AI Detection with Overlay Output ​
  • Prerequisite: AidLite 2.5.0.284 or later must be preinstalled
  • The model in this example can be downloaded from AIMO. For model adaptation details, refer to the AidLite documentation.
! rtph264depay \
! h264parse config-interval=-1 \
! video/x-raw\(memory:GBM\),format=NV12,width=1920,height=1080,framerate=25/1 \
! tee name=t \
t. ! queue max-size-buffers=4 max-size-bytes=0 max-size-time=0 ! qtimlvconverter engine=2 \
! astmlqnn model=<input-model file with location> qnn-version=<qnn version> \
! ast-mlcdetection ! text/x-raw,format=utf8 ! mux. \
mux. ! ast-overlay engine=1 \
! qtic2venc \
Plugin Type II ​
Plugin Type II Example Index ​
PlatformExample
QCS64901. Ubuntu 22.04
2. Ubuntu 24.04
3. Ubuntu 24.04 AI detection
Example 1: Ubuntu 22.04 ​
! rtph264depay \
! h264parse \
! qtivtransform \
! qtivtransform \
! h264parse \
! rtspclientsink location=<output-stream-url>
Example 2: Ubuntu 24.04 ​
gst-launch-1.0 rtspsrc location=<input-stream-url> latency=200 protocols=tcp \
! rtph264depay \
! h264parse \
! qtivtransform engine=3 \
! h264parse \
Example 3: Ubuntu 24.04 AI Detection ​
! rtph264depay \
! video/x-raw,format=NV12,width=1920,height=1080,framerate=25/1 \
! tee name=t \
! qtimlvconverter engine=3 \
mux. ! qtivoverlay \
Plugin Type III ​
This plugin type applies to the following platform and operating system:
  • Platform: QCS6490
  • Operating system: AidLux Fusion System (Ubuntu 22.04)
Before running on the 6490 AidLux Fusion System (Ubuntu 22.04), set the following environment variables:
export GST_PLUGIN_PATH=/opt/ubun20/usr/lib/aarch64-linux-gnu/gstreamer-1.0/
export LD_LIBRARY_PATH=/opt/ubun20/usr/lib/aarch64-linux-gnu/:/opt/ubun20/usr/lib:/usr/local/lib/aidlux_opencv/lib/:$LD_LIBRARY_PATH
! rtph264depay \
! h264parse \
! qtivdec \
! qtivtransform \
! qtivtransform \
! qtic2venc \
! h264parse \
SDK Interface Examples ​
To compile against the AidStream SDK C++ API, include the AidStream SDK header:
#include "aidstream.h"
When linking, specify the AidStream shared library, for example:
sh
g++ example.cpp -o demo -L/usr/local/lib/ -laidstream-gst -lopencv_core -I/usr/local/include/aidlux/aidstream-gst/ -I/usr/local/lib/aidlux_opencv/include/opencv4/
AidStream SDK header: /usr/local/include/aidlux/aidstream-gst/aidstream.h
AidStream SDK library: /usr/local/lib/libaidstream-gst.so
The only interface function that is strongly recommended for application code is:
Use this function together with the configuration file /usr/local/share/aidstream-gst/conf/aidstream-gst.conf. Because stream configurations can vary significantly, starting streams through the configuration file is strongly recommended.
The installation package also provides example programs and a matching CMakeLists.txt under /usr/local/share/aidstream-gst/example/cxx/. See the sections below for details.
Implement Push/Pull Streaming from the Sample Program ​
For configuration file details, see AidStream configuration file reference.
The default shared configuration file is aidstream-gst.conf, located in /usr/local/share/aidstream-gst/conf/.
Build and run it as follows:
Enter /usr/local/share/aidstream-gst/example/cxx/, create a build directory, and switch into it.
Run CMake in the build directory.
On the 8550 / 6490 AIBox platform:
sh
cmake ..
On the 6490 QL platform, run the following instead because it uses a different data-processing path and inference model:
sh
cmake -DV4L2=ON ..
Then run:
sh
make
After a successful build and link step, four executables are produced: demo, qnn_rtsp, rtsp, and start.
After the configuration file is set, you can quickly start a stream with the start executable:
sh
# For example, start stream ID 1
start 1
You can quickly start a push/pull stream with the built-in inference model using qnn_rtsp:
sh
# Start it the same way as `start`
qnn_rtsp 1
# Model directory: /usr/local/share/aidstream-gst/example/datas/
You can quickly start a multi-threaded push/pull stream with rtsp. The shipped example is configured for 2 threads, and you can change the code to launch more threads if needed.
sh
rtsp
Select Input and Output Streams with Configuration Parameters ​
#include <cstdlib>
#include <string>
#include <iostream>
using namespace std;
    printf("width: %d, height: %d, fps: %f, id:%s  \n", img.width, img.height, img.fps, img.stream_id.c_str());
    string _idx;
    if (argc > 1)
        _idx = argv[1];
    else
        _idx = "1";
    start_stream(_idx, callback);
Placeholder conventions:
  • <input-stream-url>: for example, rtsp://admin:aidlux123@192.168.110.234:554
  • <output-stream-url>: for example, rtsp://192.168.111.115:8554
Read an RTSP stream, perform no additional processing, and publish the output as an RTSP stream to <output-stream-url>/aidstream-gst-rtsp-test.
#include <cstdlib>
#include <string>
#include <iostream>
int main()
    string rtsp_path = "<input-stream-url>/h264/ch1/main/av_stream";
    int res = start_stream_input_rtsp(rtsp_path, my_img_cb, StreamType::RTSPSINK, "<output-stream-url>/aidstream-gst-rtsp-test");
    if (res != 0)
        return -1;
Start multiple streams at the same time without additional processing ​
#include <cstdlib>
#include <thread>
#include <string>
#include <iostream>
    t1.join();
    t2.join();
Asynchronous model processing can be used when inference latency is high.
  1. The complete sample is relatively long, so only the main function is shown below. For the full source code, see /usr/local/share/aidstream-gst/example/cxx/qnn_rtsp.cpp (for 6490 QL, refer to qnn_rtsp_v4l2.cpp).
  2. For real-time push/pull streaming, the time budget available to the application is very small. For example, at 25 fps the processing window is only 20 ms. Asynchronous processing is therefore a compromise. It can help when inference takes longer, but it cannot fully eliminate the real-time impact on display latency. In short, strict real-time responsiveness and long model inference latency are fundamentally at odds.
    // Logging is optional in most cases.
    init_share_mem_vec();
    if (argc < 2) {
        return -1;
    int r = model_init();
    if (r != 0)
        exit(1);
    bool allIDsFound = true;
    std::string arg = argv[1];
    // Start a worker thread only when the ID exists in the configuration file.
        allIDsFound = false;
    if (!allIDsFound)
        return -1;
    else
        // Main GStreamer thread for fetching frames.
        // Start three inference worker threads.
        // The required thread count depends on model latency.
        // Longer inference times require more workers. For example,
        // if inference takes 50 to 60 ms, three workers are typically enough.
        // If the model does not support concurrency, use only one worker.
    for (auto &t : threads)
        if (t.joinable())
            t.join();
