Pin Definition & Usage ​
Rhino Pi-X1 features two on-board 40-PIN GPIO interfaces:
  • 40-Pin 3.3V GPIO (Raspberry Pi compatible)
  • 40-Pin 1.8V GPIO
Warning
When using the 40-Pin GPIO interfaces, pay close attention to the wiring between pins and peripherals. Ensure correct pin connections—improper operation may cause hardware damage to the device.
40-Pin 3.3V GPIO (Raspberry Pi Compatible) ​
Rhino Pi-X1 is equipped with an on-board 40-PIN 2.5mm pitch box header for 3.3V GPIO expansion, providing highly flexible interface support for hardware expansion. Users can connect various sensors, communication modules, displays, and other embedded peripherals via this interface to achieve rapid prototyping and functional verification in fields such as Internet of Things (IoT), robot control, and industrial automation.
The multiplexing functions of the 40-Pin 3.3V GPIO are shown in the table below:
FunctionPIN#PIN#Function
3.3V OUT125V OUT
I2C1_SDA345V OUT
I2C1_SCL56GND
GPIO_0078GPIO_12
GND910GPIO_01
GPIO_051112LPI_I2S2_CLK
I2C4_SDA1314GND
I2C4_SCL1516UART_RX
3.3V OUT1718GPIO_61
SPI3_MOSI1920GND
SPI3_MISO2122GPIO_118
SPI3_CLK2324SPI3_CS0
GND2526GPIO_22
GPIO_322728GPIO_33
UART_TX2930GND
GPIO_623132GPIO_91
GPIO_1243334GND
LPI_I2S2_WS3536GPIO_63
GPIO_603738LPI_I2S2_DATA0
GND3940LPI_I2S2_DATA1
40-Pin 1.8V GPIO ​
Rhino Pi-X1 is equipped with an on-board 40-PIN 2.5mm pitch box header for 1.8V GPIO expansion, enabling better compatibility with peripherals requiring different IO voltage levels. The multiplexing functions of the 40-Pin 1.8V GPIO are shown in the table below:
NC121.8V OUT
NC34GND
GPIO_7156I2S1_CLK
NC78I2S1_WS
GND910I2S1_DATA0
GPIO_361112I2S1_DATA1
GPIO_371314GND
Uart TX15161.8V/100mA
Uart RX1718SENSOR_I3C_SCL
GPIO_062324SENSOR_I2C_SDA
ADC IN02526I2S3_DATA1
Debug_UART_TX27285V OUT/300mA
Debug_UART_RX2930I2S3_DATA0
I2S3_CLK3132ADC IN1
I2S3_WS3334GND
GND3536ADC IN2
CAN_L3738GND
CAN_H3940PWM
