AidGen SDK Developer Guide ​
AidGen is an inference framework specifically designed for generative Transformer models, built on top of AidLite. It aims to fully utilize various computing units of the hardware (CPU, GPU, NPU) to achieve inference acceleration for large models on edge devices.
AidGen is an SDK-level development kit that provides atomic-level large model inference interfaces, suitable for developers who want to integrate large model inference into their own applications.
AidGen supports multiple types of generative AI models:
  • Language large models -> AidLLM inference
  • Multimodal large models -> AidMLM inference
The structure is shown in the diagram below:
AidGen Structure
All large models supported by Model Farm achieve inference acceleration on Qualcomm chip NPUs through AidGen.
Support Status ​
Model Type Support
AidLLMAidMLM
Text✅/
Image/✅
Audio/🚧
✅: Supported 🚧: Planned support
Operating System Support
LinuxAidLuxAndroid
C++✅✅/
Python🚧🚧/
Java//🚧
Large Language Model AidLLM SDK ​
Installation ​
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
# Copy test code
cd /home/aidlux/aidllm
Model File Acquisition ​
  1. Model files and default configuration files can be downloaded directly from the Model Farm Large Model Section.
  2. Retrieve and download the model via the command line, using Qwen2.5-0.5B-Instruct as an example:
# Log in
mms login
# Search for the model
# Download the model
mv qnn229_qcs8550_cl4096/* /home/aidlux/aidllm/
Model Performance Monitoring ​
Please ensure that the sample application can run to completion successfully.
Taking the example Deploying Qwen2.5-0.5B-Instruct on Qualcomm QCS8550:
# Compile
mkdir build && cd build
cmake .. && make
./test_text_only qwen2.5-0.5b-instruct-htp.json "hi"
  • After entering the conversation content in the terminal, you will see the following log information:
Log Information
Example Applications ​
Multi-modal Vision Model AidMLM SDK ​
Model Support
ModelStatus
Qwen2.5-VL-3B-Instruct✅
Qwen2.5-VL-7B-Instruct✅
InternVL3-2B🚧
Qwen3-VL-4b🚧
Qwen3-VL-2b🚧
Installation ​
# Copy test code
mkdir /home/aidlux/aidmlm
cd /home/aidlux/aidmlm
Since Qwen2.5-VL-3B (392x392) is currently in the Model Farm preview section, it must be retrieved via the mms command.
# Log in
mms login
mms list Qwen2.5-VL-3B
Create Configuration File ​
vim config3b_392.json
Create the following json configuration file:
json
    "backend_type": "genie",
    "model": {},
    "vlm_model":{
        "llm_path_list":[
/home/aidlux/aidmlm
├── full_attention_mask.raw
├── position_ids_cos.raw
├── position_ids_sin.raw
├── veg.serialized.bin.aidem
├── window_attention_mask.raw
├── examples
Taking the example Deploying Qwen2.5-VL-3B-Instruct (392x392) on Qualcomm QCS8550:
cmake .. && make
# Manually upload an image to the /home/aidlux/aidmlm/ directory
./test_multimodal config3b_392.json test-1.jpg "Please describe this image"
Log Information
Modifying Inference Parameters ​
AidGen supports dynamic modification of parameters related to model inference. Currently supported parameters include:
  • temp
  • top-k
  • top-p
  • stream
Refer to the following code in the test_aidgen_text.cpp file to modify parameters:
    // Set generator property
    std::cout << "[API] Generator::set_property(\"stream\", \"1\")" << std::endl;
