Browser Login ​
Prerequisites ​
  • Mainboard: Rhino Pi A1
  • Power Supply: DC12V/24V 3A Power Adapter
  • Input Device: USB TYPE-A to TYPE-C Cable
  • Communication Device: Ordinary Network Cable
Start the Board ​
The board is pre-installed with Android 14 system. After powering with DC12V/24V 3A power adapter, the board will automatically start the system.
  • Boot Process: Power indicator red light stays on
  • Use USB TYPE-A to TYPE-C cable, TYPE-A port connects to Windows PC USB port, TYPE-C port connects to board C port.
  • System Normal Startup: RGB light red light stays on and fan rotates and works, indicating boot completion
Get IP Address via ADB ​
Install ADB Software ​
Visit link ADB Download select corresponding platform to download ADB software.
Open Terminal in ADB folder directory, input adb output ADB related command description means environment is normal
Tip
More ADB usage please refer to ADB Basic Usage.
IP Address Acquisition ​
# Enter device
# Get IP address
ifconfig eth0
You can see the following output:
inet addr parameter indicates the device's IP address
Tip
More IP address acquisition methods please refer to IP Address Acquisition.
Login to Web Page ​
After getting the device's IP address, you can login to the fusion system's Web interface as follows.
  • Ensure PC and board are on the same LAN
  • Enter url in browser: http://ip:8000/login Please replace ip in url with device's actual ip address. Username/Password: aidlux/aidlux
Use the System ​
After successfully starting the system, developers can officially use Ubuntu 22.04 system on Rhino Pi-A1, can refer to System Usage
Tip
If developers need to reinstall the system or OTA upgrade, please refer to: System Flashing
