AidConnect Android API Documentation ​
💡Note When developing with Aidconnect-SDK C++, the following points need to be noted:
  • The header file must be included during compilation, stored at: /usr/local/include/aidlux/aidconnect/aidconnect.hpp
  • The library file must be specified during linking, stored at: /usr/local/lib/aidlux/aidconnect/libaidconnect.so
enum struct LogLevel ​
Member Variable NameTypeDefault ValueDescription
DEBUGuint8_t0Debug log level
INFOuint8_t1Info log level
WARNINGuint8_t2Warning log level
ERRORuint8_t3Error log level
Class AidConnect ​
A shared memory communication class implemented based on C++.
get_library_version() ​
APIget_library_version
DescriptionUsed to obtain version-related information of the current Aidconnect.
Parametersvoid
ReturnReturns a string containing the version information of the current Aidconnect
set_log_level() ​
APIset_log_level
DescriptionSets the current minimum log level, and outputs log data with levels greater than or equal to this level.
By default, logs of WARNING level and above are printed.
Parameterslog_level: Value of the enumeration type LogLevel
ReturnReturns 0 by default
init() ​
As the name implies, this function implements relevant initialization work.
APIinit
DescriptionCompletes relevant initialization work
Parametersvoid
Return0 indicates the initialization operation is successful; a non-0 value indicates failure
if(EXIT_SUCCESS != status){
aidconnect_with_name() ​
This function is used to specify which shared memory block we need to use. It should be noted that this interface only checks whether a shared memory block exists and does not create new shared memory (the creation of shared memory is implemented by the Android-side interface).
APIaidconnect_with_name
DescriptionSpecifies the use of a specific shared memory block
Parametersname: ID string of a specific shared memory block
Return0 indicates the operation is successful; a non-0 value indicates failure
set_bytes() ​
This function writes byte data to the corresponding shared memory.
APIset_bytes
DescriptionWrites byte data to the corresponding shared memory
Parametersbuffer: Memory address storing the data
len: Byte length of the data to be written
Return0 indicates the write operation is successful; a non-0 value indicates failure
get_bytes() ​
This function reads the required byte data from the corresponding shared memory.
APIget_bytes
DescriptionReads the required byte data from the corresponding shared memory
Parametersbuffer: Address of a pointer variable; the function copies data to this pointer variable address
len: Byte length of the data to be obtained.If the 'len' parameter is set to 0, it will by default read all the data that has been written to the memory
Return0 indicates the read operation is successful; a non-0 value indicates failure
NoteBefore using this interface, developers need to allocate the required memory by themselves to store the data obtained from the shared memory
AidConnect C++ Sample Program ​
The AidConnect-SDK sample program is installed with the software package:
  • C++ sample program path: /usr/local/share/aidconnect/examples/cpp/
The C++ sample program here roughly includes the following parts:
Initialization ​
Initialization is a mandatory step, which will complete prerequisites such as configuration parsing.
Associate a Specific Shared Memory Block ​
To achieve data interaction, the entities that need to exchange data must focus on the same shared memory block and perform read/write operations on it.
Read and Write Data ​
The essence of data interaction is the read/write operation of the same data. Here is an example of a write operation:
char buffer[] = "Hello Cpp";
Similarly, the read operation follows the same steps: initialize first, then associate the shared memory block, and finally call the data reading interface to obtain data.
