TOF Sensing ​
Nooploop TOF Sensor ​
Preparation ​
  • Rhino Pi A1
  • Nooploop TOFSense series TOF sensor
  • USB TO 4CH TTL serial expansion device
  • Additional cables
Hardware Connection ​
Use the CH344 serial adapter to connect the TOF sensor VCC, GND, TX, and RX to any UART port on the CH344 device. This example uses UART0.
Test ​
After connecting, open minicom in the AidLux terminal. If minicom is not installed, install it with:
sudo apt update; sudo apt install minicom
Open the serial port:
sudo minicom -D /dev/ttyCH343USB0 -b 921600 -H
The TOF sensor default baud rate is 921600 and requires hexadecimal display.
Note: If minicom only shows one line, configure line wrapping:
Press Ctrl-A, then Z, then press W.
The following is an example of received data:
