48-Pin GPIO Connector ​
Rhino Pi A1 includes a 2x24-pin GPIO connector on board.
Danger
When using the 48-pin GPIO connector, pay attention to pin wiring and peripheral connections. Incorrect wiring may damage the hardware.
48-Pin 3.3V GPIO Expansion Connector ​
The Rhino Pi A1 includes a 2x24-pin interface that provides flexible expansion support for hardware. Users can connect sensors, communication modules, displays, and other embedded peripherals via this interface for rapid prototyping in IoT, robotics control, and industrial automation.
The 48-pin 3.3V GPIO expansion connector includes the following functions:
CategoryInterfaceDescription
Signal conversionCAN interface2 CAN FD channels
Signal conversionRS4851 RS485 channel
Signal conversionRS2322 RS232 channels
Signal conversionOptocoupler2 inputs, 2 outputs, 5-30V range
Reserved signal interfaceI2S1 channel
Reserved signal interfaceSPI1 channel
Reserved signal interfaceDEBUG UART1 channel
Reserved signal interfaceUART1 channel
Reserved signal interfaceGPIO5 channels
Reserved signal interface5V1 channel
Reserved signal interface3.3V1 channel
Basic Interface Tests ​
GPIO ​
GPIO Introduction
General-purpose input/output (GPIO) pins are non-specialized digital pins on an integrated circuit or electronic board (such as MCU/MPU). They can be used as inputs or outputs and are controlled by software.
Preparation ​
  • Rhino Pi A1
  • Multimeter
  • Open-source tool gpiod
Connection ​
This example uses the 5V pin (GPIO117) on the Rhino Pi A1 48-pin connector.
  • Turn on the multimeter and set it to the DC voltage 10V range.
  • Connect the multimeter red probe to the 5V pin (GPIO117) on the Rhino Pi A1.
  • Connect the multimeter black probe to the Rhino Pi A1 GND pin.
Test ​
  • Output high level:
sudo gpioset /dev/gpiochip3 117=1
Observe approximately 5V on the multimeter.
  • Output low level:
sudo gpioset /dev/gpiochip3 117=0
Observe approximately 0V on the multimeter.
More Interface Applications ​
For more 48 PIN interface applications please refer to 48 PIN Pin Application.
