TOF Sensing
Nooploop TOF Sensor
- Official documentation: Nooploop TOFSense Series
Preparation
- Rhino Pi A1
- Nooploop TOFSense series TOF sensor
- USB TO 4CH TTL serial expansion device
- Additional cables
Hardware Connection
Use the CH344 serial adapter to connect the TOF sensor VCC, GND, TX, and RX to any UART port on the CH344 device. This example uses UART0.
Test
After connecting, open minicom in the AidLux terminal. If minicom is not installed, install it with:
sudo apt update; sudo apt install minicomOpen the serial port:
sudo minicom -D /dev/ttyCH343USB0 -b 921600 -HThe TOF sensor default baud rate is 921600 and requires hexadecimal display.
Note: If minicom only shows one line, configure line wrapping:
Press Ctrl-A, then Z, then press W.
The following is an example of received data:
