WIFI / BT Antenna Interface ​
  • Wi-Fi: 802.11ax, 2.4G/5G bands, 2x2 MIMO
  • Bluetooth supports BT 5.2
Hardware Connection ​
Install antennas on the Rhino Pi A1 antenna interfaces. When using WIFI/BT functions, install two antennas to enhance WIFI/BT transmission power and reception sensitivity.
Refer to the Hardware Information guide to locate the interfaces.
Recommended antenna: AIWF022 antenna
Bluetooth Usage ​
Rhino Pi A1 fusion system's Bluetooth connection, only need to connect on Android side, connection method as follows:
  • Open Android home page, left-click mouse and slide up on screen, find Settings option in the appeared page.
  • Click Settings - Connected devices - Pair new device, perform Bluetooth scan and connection.
