Pin Definition ​
Pin Definition
Connectors ​
The core board connects to the base board through the following Panasonic board-to-board connectors:
ConnectorModelMating Connector Model
J1, J2, J3Panasonic AXK600337YGAXK500137YG
J4Panasonic AXK680337YGAXK580137YG
J1 Pin Definition ​
PIN#Pin SignalI/ODescriptionNotes
88,90,92,94,96,98,100USB_VBUSPI/POUSB_VBUS, supports QC5.0 fast charge input, voltage range 3.7 V to 21.5 V
85,87,89,91,93,95,97,99VBATTPICore board power supply, voltage range 3.5 to 4.2 V
84,86VREG_BOB1POCore board output BUCK OR BOOST, powers CODEC IC
1,2,24,27,44,50,51,55,59,74,76,77,78,79,80,81,82,83GNDGDigital ground
75VCOINPI/PORTC backup power
73VBATT_CONN_VSENSE_PAIBattery voltage sense signal
71VBATT_CONN_VSENSE_MAIBattery voltage sense signal
72PM8550_THERM1AIPM8550 ADC1
70PM8550_THERM4AIPM8550 ADC4
69VBATT_PACK_SNS_MAIRemote sense for second cell voltage in 1S2P battery
67BATT_IDAIBattery identification, detection, and BSI communication
65BATT_THERMAIBattery temperature sensor
63USB0_THERMAIType-C temperature sensor
61USB_LD_SW_ENI/OPM8550B GPIO03
66,68VREG_S6G_1P86PO1.8 V output
64VREG_L8B_1P8PO1.8 V outputSD card level shifter power
62VREG_L6B_1P8PO1.8 V output
60VREG_1P2_SYSPO1.2 V outputSD card level shifter power
58VREG_L13B_3P0PO3 V output
56VREG_L14B_3P2PO3 V output
54VREG_L15B_1P8PO1.8 V output
52VREG_L16B_2P8PO2.8 V output
48USB0_HS_DMI/OUSB0 data -USB 2.0 OTG
46USB0_HS_DPI/OUSB0 data +USB 2.0 OTG
57PMK_CLK7_LNAOReserved 38.4 MHz clock output
53SLEEP_CLKAO32.7645 kHz clock outputWiFi sleep clock
49AOSS_SLEEP_INDICATORAIReserved Always-On SubSystem sleep detection signal
47GPIO4_I2C1_SDAODGeneral-purpose I2C bus, 1.8 V level
45GPIO5_I2C1_SCLODGeneral-purpose I2C bus, 1.8 V level
43GPIO14*DIGPIO14, 1.8 V level
42PM_CBL_PWR_NI/OBoot config signal, auto power-onActive low
41GPIO16*I/OGPIO16, 1.8 V level
40KPD_PWR_NDIPower on/off signal, active low
39GPIO17*I/OGPIO17, 1.8 V level
38PM_RESIN_NDIReset signal, active low
37GPIO18*I/OGPIO18, 1.8 V level
36PM_KYPD_VOLP_NDIVolume control signal
35GPIO19*I/OGPIO19, 1.8 V level
34GPIO7I/OGPIO7, 1.8 V levelCamera power control signal
33GPIO20_I2C_SDAODGeneral-purpose I2C bus, 1.8 V level
31GPIO21_I2C_SDAODGeneral-purpose I2C bus, 1.8 V level
32GPIO8*DIGPIO8, 1.8 V level
30GPIO6DOGPIO6, 1.8 V level
29PM8550_PWM_OUT_GPIO9DOPM8550 PWM4For eDP/MIPI LCM backlight adjustment
28USB0_OVP_SNSAIUSB charging overvoltage detection
26USB0_OVP_DRVAOUSB overvoltage protection FET drive signal
25DSI0_NC_CLK1_MAOMIPI DSI0 clock signalFor Split-link
23DSI0_NC_CLK1_PAOMIPI DSI0 clock signalFor Split-link
21DSI0_NC_LN3_MAOMIPI DSI0 data signalDSI0
19DSI0_C2_LN3_PAOMIPI DSI0 data signalDSI0
17DSI0_C1_CLK_MAOMIPI DSI0 clock signalDSI0
15DSI0_B1_CLK_PAOMIPI DSI0 clock signalDSI0
13DSI0_A0_LN0_PAOMIPI DSI0 data signalDSI0
11DSI0_B0_LN0_MAOMIPI DSI0 data signalDSI0
9DSI0_B2_LN2_MAOMIPI DSI0 data signalDSI0
7DSI0_A2_LN2_PAOMIPI DSI0 data signalDSI0
5DSI0_C0_LN1_PAOMIPI DSI0 data signalDSI0
3DSI0_A1_LN1_MAOMIPI DSI0 data signalDSI0
22DSI1_A0_LN0_PAOMIPI DSI1 data signalDSI1
20DSI1_B0_LN0_MAOMIPI DSI1 data signalDSI1
18DSI1_C0_LN1_PAOMIPI DSI1 data signalDSI1
16DSI1_A1_LN1_MAOMIPI DSI1 data signalDSI1
14DSI1_B1_CLK_PAOMIPI DSI1 clock signalDSI1
12DSI1_C1_CLK_MAOMIPI DSI1 clock signalDSI1
10DSI1_C2_LN3_PAOMIPI DSI1 data signalDSI1
8DSI1_NC_LN3_MAOMIPI DSI1 data signalDSI1
6DSI1_B2_LN2_MAOMIPI DSI1 data signalDSI1
4DSI1_A2_LN2_PAOMIPI DSI1 data signalDSI1
J2 Pin Definition ​
1GPIO63_UART3_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
3GPIO62_UART3_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
2GPIO71_UART4_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
4GPIO70_UART4_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
5GPIO61I/OGPIO61, 1.8 V level
6GPIO69I/OGPIO69, 1.8 V level
7*GPIO60I/OGPIO60, 1.8 V level
8GPIO68I/OGPIO68, 1.8 V level
9GPIO119_UART8_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
11GPIO118_UART8_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
10GPIO67_SPI_CSNDOSPI chip select, 1.8 V levelGeneral-purpose SPI
12GPIO66_SPI_CLKDOSPI clock, 1.8 V levelGeneral-purpose SPI
14GPIO65_SPI_MOSIDOSPI MOSI, 1.8 V levelGeneral-purpose SPI
16GPIO64_SPI_MISODISPI MISO, 1.8 V levelGeneral-purpose SPI
13GPIO120_CAM4_RST_NDOCamera 4 reset, 1.8 V levelRST for CSI4
15GPIO122_CAM3_RST_NDOCamera 3 reset, 1.8 V levelRST for CSI3
17GPIO121_CAM2_RST_NDOCamera 2 reset, 1.8 V levelRST for CSI2
19GPIO117_CAM1_RST_NDOCamera 1 reset, 1.8 V levelRST for CSI1
21GPIO116_CAM0_RST_NDOCamera 0 reset, 1.8 V levelRST for CSI0
18,20VREG_L9B_2P9PO1.8/2.95 V outputTF card power
22SDC2_CD_NDISD card detect, active lowTF card
24SDC2_DATA_3_1V2I/OSD data line, 1.2 V levelTF card
26SDC2_DATA_2_1V2I/OSD data line, 1.2 V levelTF card
28SDC2_DATA_1_1V2I/OSD data line, 1.2 V levelTF card
30SDC2_DATA_0_1V2I/OSD data line, 1.2 V levelTF card
32SDC2_CMD_1V2I/OSD command line, 1.2 V levelTF card
34SDC2_CLK_1V2DOSD clock line, 1.2 V levelTF card
23AON_CCI_I2C_SDA3I/OCamera-dedicated I2CAON, for CSI4
25AON_CCI_I2C_SCL3I/OCamera-dedicated I2CAON, for CSI4
27CCI_I2C_SDA2I/OCamera-dedicated I2CFor CSI3
29CCI_I2C_SCL2I/OCamera-dedicated I2CFor CSI3
31CCI_I2C_SDA1I/OCamera-dedicated I2CFor CSI2
33CCI_I2C_SCL1I/OCamera-dedicated I2CFor CSI2
35CCI_I2C_SDA0I/OCamera-dedicated I2CFor CSI0/1
37CCI_I2C_SCL0I/OCamera-dedicated I2CFor CSI0/1
41CAM_AON_MCLK4DOCamera master clockAON, for CSI4
43CAM_MCLK3DOCamera master clockFor CSI3
45CAM_MCLK2DOCamera master clockFor CSI2
47CAM_MCLK1DOCamera master clockFor CSI1
49CAM_MCLK0DOCamera master clockFor CSI0
53CSI3_C2_LN3_MAOMIPI CSI3 data signal4-Lane
55CSI3_B2_LN3_PAOMIPI CSI3 data signal4-Lane
57CSI3_A2_LN2_MAOMIPI CSI3 data signal4-Lane
59CSI3_C1_LN2_PAOMIPI CSI3 data signal4-Lane
61CSI3_B1_LN1_MAOMIPI CSI3 data signal4-Lane
63CSI3_A1_LN1_PAOMIPI CSI3 data signal4-Lane
65CSI3_C0_LN0_MAOMIPI CSI3 data signal4-Lane
67CSI3_B0_LN0_PAOMIPI CSI3 data signal4-Lane
71CSI3_A0_CLK_MAOMIPI CSI3 clock signal4-Lane
73CSI3_NC_CLK_PAOMIPI CSI3 clock signal4-Lane
77CSI1_C2_LN3_MAOMIPI CSI1 data signal4-Lane
79CSI1_B2_LN3_PAOMIPI CSI1 data signal4-Lane
81CSI1_A2_LN2_MAOMIPI CSI1 data signal4-Lane
83CSI1_C1_LN2_PAOMIPI CSI1 data signal4-Lane
85CSI1_B1_LN1_MAOMIPI CSI1 data signal4-Lane
87CSI1_A1_LN1_PAOMIPI CSI1 data signal4-Lane
89CSI1_C0_LN0_MAOMIPI CSI1 data signal4-Lane
91CSI1_B0_LN0_PAOMIPI CSI1 data signal4-Lane
95CSI1_A0_CLK_MAOMIPI CSI1 clock signal4-Lane
97CSI1_NC_CLK_PAOMIPI CSI1 clock signal4-Lane
38CSI4_C2_LN3_MAOMIPI CSI4 data signalAON, 4-Lane
40CSI4_B2_LN3_PAOMIPI CSI4 data signalAON, 4-Lane
42CSI4_A2_LN2_MAOMIPI CSI4 data signalAON, 4-Lane
44CSI4_C1_LN2_PAOMIPI CSI4 data signalAON, 4-Lane
46CSI4_B1_LN1_MAOMIPI CSI4 data signalAON, 4-Lane
48CSI4_A1_LN1_PAOMIPI CSI4 data signalAON, 4-Lane
50CSI4_C0_LN0_MAOMIPI CSI4 data signalAON, 4-Lane
52CSI4_B0_LN0_PAOMIPI CSI4 data signalAON, 4-Lane
56CSI4_A0_CLK_MAOMIPI CSI4 clock signalAON, 4-Lane
58CSI4_NC_CLK_PAOMIPI CSI4 clock signalAON, 4-Lane
62CSI2_C2_LN3_MAOMIPI CSI2 data signal4-Lane
64CSI2_B2_LN3_PAOMIPI CSI2 data signal4-Lane
66CSI2_A2_LN2_MAOMIPI CSI2 data signal4-Lane
68CSI2_C1_LN2_PAOMIPI CSI2 data signal4-Lane
70CSI2_B1_LN1_MAOMIPI CSI2 data signal4-Lane
72CSI2_A1_LN1_PAOMIPI CSI2 data signal4-Lane
74CSI2_C0_LN0_MAOMIPI CSI2 data signal4-Lane
76CSI2_B0_LN0_PAOMIPI CSI2 data signal4-Lane
80CSI2_A0_CLK_MAOMIPI CSI2 clock signal4-Lane
82CSI2_NC_CLK_PAOMIPI CSI2 clock signal4-Lane
86CSI0_B1_LN1_MAOMIPI CSI0 data signal2-Lane
88CSI0_A1_LN1_PAOMIPI CSI0 data signal2-Lane
90CSI0_C0_LN0_MAOMIPI CSI0 data signal2-Lane
92CSI0_B0_LN0_PAOMIPI CSI0 data signal2-Lane
96CSI0_A0_CLK_MAOMIPI CSI0 clock signal2-Lane
98CSI0_NC_CLK_PAOMIPI CSI0 clock signal2-Lane
36,39,51,54,60,69,75,78,84,93,94,99,100GNDGDigital ground
J3 Pin Definition ​
1DEBUG_UART_TXDOUART data output, 1.8 V levelDebug UART
3DEBUG_UART_RXDIUART data input, 1.8 V levelDebug UART
5GPIO30_UART1_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
7GPIO31_UART1_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
2GPIO36_SPI_MISODISPI MISO, 1.8 V levelGeneral-purpose SPI
4GPIO37_SPI_MOSIDOSPI MOSI, 1.8 V levelGeneral-purpose SPI
6GPIO38_SPI_CLKDOSPI clock, 1.8 V levelGeneral-purpose SPI
8GPIO39_SPI_CSNDOSPI chip select, 1.8 V levelGeneral-purpose SPI
10GPIO42_INT_N*I/OGPIO42, 1.8 V level
9GPIO56_INT_N*I/OGPIO56, 1.8 V level
15GPIO32_SPI_MISODISPI MISO, 1.8 V levelGeneral-purpose SPI
17GPIO33_SPI_MOSIDOSPI MOSI, 1.8 V levelGeneral-purpose SPI
19GPIO34_SPI_CLKDOSPI clock, 1.8 V levelGeneral-purpose SPI
21GPIO35_SPI_CSNDOSPI chip select, 1.8 V levelGeneral-purpose SPI
11GPIO28*DOGPIO28, 1.8 V level
13GPIO29DOGPIO29, 1.8 V level
12GPIO40*DOGPIO40, 1.8 V level
14GPIO41*DOGPIO41, 1.8 V level
16GPIO44_TP_I2C_SDAI/OGeneral-purpose I2C bus, 1.8 V levelI2C touch communication
18GPIO45_TP_I2C_SCLDOGeneral-purpose I2C bus, 1.8 V levelI2C touch communication
20GPIO133*I/OGPIO133, 1.8 V level
22GPIO137*I/OGPIO137, 1.8 V level
24GPIO25_TP_INT*DIGPIO25, 1.8 V levelI2C touch interrupt
26GPIO24_TP_RSTDOGPIO24, 1.8 V levelI2C touch reset
23FORCE_USB_BOOTDIFlashing mode signal
25GPIO_188_I2C_SDAI/OGeneral-purpose I2C bus, 1.8 V level
27GPIO_189_I2C_SCLDOGeneral-purpose I2C bus, 1.8 V level
29GPIO125_I2S_MCLKI/OI2S master clock, 1.8 V levelNon-LPI I2S
33GPIO126_I2S_SCKI/OI2S clock, 1.8 V levelNon-LPI I2S
35GPIO129_I2S_WSI/OI2S word select, 1.8 V levelNon-LPI I2S
37GPIO127_I2S_DATA0I/OI2S data channel 0, 1.8 V levelNon-LPI I2S
39GPIO128_I2S_DATA1I/OI2S data channel 1, 1.8 V levelNon-LPI I2S
30GPIO48*I/OGPIO48, 1.8 V level
32GPIO49I/OGPIO49, 1.8 V level
34GPIO50_UART2_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
36GPIO51_UART2_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
38GPIO202I/OGPIO202, 1.8 V level
40GPIO203*I/OGPIO203, 1.8 V level
41GPIO74_UART5_TXDOUART data output, 1.8 V levelGeneral-purpose UART
43GPIO75_UART5_RXDIUART data input, 1.8 V levelGeneral-purpose UART
42GPIO_204DOGPIO204, 1.8 V levelHost wake Bluetooth signal
44GPIO_205*DIGPIO205, 1.8 V levelWi-Fi wake host signal
45GPIO_76_BT_UART_CTSDO4-wire UART, 1.8 V levelAP6275P, Bluetooth
47GPIO_77_BT_UART_RFRDI4-wire UART, 1.8 V levelAP6275P, Bluetooth
49GPIO_78_BT_UART_TXDO4-wire UART, 1.8 V levelAP6275P, Bluetooth
51GPIO_79_BT_UART_RXDI4-wire UART, 1.8 V levelAP6275P, Bluetooth
46GPIO84*DIGPIO84, 1.8 V levelBluetooth wake host signal
48GPIO85*I/OGPIO85, 1.8 V level
50GPIO86*I/OGPIO86, 1.8 V level
52GPIO87*I/OGPIO87, 1.8 V level
53GPIO80_SPI_MISODISPI MISO, 1.8 V levelGeneral-purpose SPI
55GPIO81_SPI_MOSIDOSPI MOSI, 1.8 V levelGeneral-purpose SPI
57GPIO82_SPI_CLKDOSPI clock, 1.8 V levelGeneral-purpose SPI
59GPIO83_SPI_CSNDOSPI chip select, 1.8 V levelGeneral-purpose SPI
54GPIO_80DOGPIO80, 1.8 V levelWi-Fi enable signal
56GPIO_81DOGPIO81, 1.8 V levelBluetooth enable signal
58GPIO90I/OGPIO90, 1.8 V level
60GPIO91I/OGPIO91, 1.8 V level
61GPIO58_UART6_TXDOUART data output, 1.8 V levelGeneral-purpose UART
63GPIO59_UART6_RXDIUART data input, 1.8 V levelGeneral-purpose UART
62PM8010_1_RESET_NDOReserved PM8010 reset signal
64PM8010_2_RESET_NDOReserved PM8010 reset signal
67SM_PCIE0_RESET_NDOPCIe0 reset, 1.8 V levelPCIe Gen3
69SM_PCIE0_CLK_REQ_NDIPCIe0 clock request, 1.8 V levelPCIe Gen3
71SM_PCIE0_WAKE_NDIPCIe0 wake, 1.8 V levelPCIe Gen3
75SOM_PCIE0_RX1_PAIPCIe0 data inputPCIe Gen3
77SOM_PCIE0_RX1_MAIPCIe0 data inputPCIe Gen3
79SOM_PCIE0_RX0_MAIPCIe0 data inputPCIe Gen3
81SOM_PCIE0_RX0_PAIPCIe0 data inputPCIe Gen3
85SOM_PCIE0_REFCLK_MDOPCIe0 reference clockPCIe Gen3
87SOM_PCIE0_REFCLK_PDOPCIe0 reference clockPCIe Gen3
91SOM_PCIE0_TX1_MAOPCIe0 data outputPCIe Gen3
93SOM_PCIE0_TX1_PAOPCIe0 data outputPCIe Gen3
95SOM_PCIE0_TX0_MAOPCIe0 data outputPCIe Gen3
97SOM_PCIE0_TX0_PAOPCIe0 data outputPCIe Gen3
68SM_PCIE1_RESET_NDOPCIe1 reset, 1.8 V levelPCIe Gen4
70SM_PCIE1_CLK_REQ_NDIPCIe1 clock request, 1.8 V levelPCIe Gen4
72SM_PCIE1_WAKE_NDIPCIe1 wake, 1.8 V levelPCIe Gen4
76SOM_PCIE1_RX1_MAIPCIe1 data inputPCIe Gen4
78SOM_PCIE1_RX1_PAIPCIe1 data inputPCIe Gen4
80SOM_PCIE1_RX0_PAIPCIe1 data inputPCIe Gen4
82SOM_PCIE1_RX0_MAIPCIe1 data inputPCIe Gen4
86SOM_PCIE1_REFCLK_MDOPCIe1 reference clockPCIe Gen4
88SOM_PCIE1_REFCLK_PDOPCIe1 reference clockPCIe Gen4
92SOM_PCIE1_TX1_MAOPCIe1 data outputPCIe Gen4
94SOM_PCIE1_TX1_PAOPCIe1 data outputPCIe Gen4
96SOM_PCIE1_TX0_MAOPCIe1 data outputPCIe Gen4
98SOM_PCIE1_TX0_PAOPCIe1 data outputPCIe Gen4
28,31,65,66,73,74,83,84,89,90,99,100GNDGDigital ground
J4 Pin Definition ​
1GPIO_47_DP_HPDDIDP hot-plug detectDP specific
2GPIO_176*I/OGPIO176, 1.8 V level
3GPIO_46*I/OGPIO46, 1.8 V level
4GPIO_175I/OGPIO175, 1.8 V level
5GPIO_108I/OGPIO108, 1.8 V level
6GPIO_174_I2S1_DAT1I/OI2S1 data signalLPI I2S
8GPIO_173_I2S1_DATA0I/OI2S1 data signalLPI I2S
10GPIO_172_I2S1_WSDOI2S1 word selectLPI I2S
12GPIO_171_I2S1_CLKDOI2S1 clockLPI I2S
7GPIO55_UART_RXDDIUART data input, 1.8 V levelGeneral-purpose UART
9GPIO54_UART_TXDDOUART data output, 1.8 V levelGeneral-purpose UART
11GPIO_164_WDOG_DISABLEI/OReserved config GPIO, WDOG enable
13GPIO183I/OGPIO183, 1.8 V level
15GPIO182_HP_DET_LDIHeadphone insertion detectFor WCD9385
17GPIO181_USB30_PWR_EN*I/OGPIO181, 1.8 V level
19GPIO180_USB20_PWR_ENI/OGPIO180, 1.8 V level
16GPIO_168_SWR_RX_CLKDOSoundWire RX clockFor WCD9385
18GPIO_169_SWR_RX_DATA0I/OSoundWire RX dataFor WCD9385
20GPIO_170_SWR_RX_DATA1I/OSoundWire RX dataFor WCD9385
22GPIO_179_SWR_TX_DATA2I/OSoundWire TX dataFor WCD9385
24GPIO_167_SWR_TX_DATA1I/OSoundWire TX dataFor WCD9385
26GPIO_166_SWR_TX_DATA0I/OSoundWire TX dataFor WCD9385
28GPIO_165_SWR_TX_CLKDOSoundWire TX clockFor WCD9385
23USB0_DP_AUX_PI/ODP auxiliary signal
25USB0_DP_AUX_NI/ODP auxiliary signal
29USB0_SS_TX1_MAI/AOUSB 3.1 / DP output data
31USB0_SS_TX1_PAI/AOUSB 3.1 / DP output data
33USB0_SS_TX0_MAI/AOUSB 3.1 / DP output data
35USB0_SS_TX0_PAI/AOUSB 3.1 / DP output data
39USB0_SS_RX0_PAI/AOUSB 3.1 / DP input data
41USB0_SS_RX0_MAI/AOUSB 3.1 / DP input data
43USB0_SS_RX1_PAI/AOUSB 3.1 / DP input data
45USB0_SS_RX1_MAI/AOUSB 3.1 / DP input data
32AON_CAM_STB1DOAON CAM Standby signalCAM
34AON_CAM_STB0DOAON CAM Standby signalCAM
36GPIO195_SPI_CSNDOSPI chip select, 1.8 V levelSSC_QUP_SPI
38GPIO194_SPI_SCKDOSPI clock, 1.8 V levelSSC_QUP_SPI
40GPIO193_SPI_MOSIDOSPI MOSI, 1.8 V levelSSC_QUP_SPI
42GPIO192_SPI_MISODISPI MISO, 1.8 V levelSSC_QUP_SPI
44GPIO191_I2C_SCLDOI2C clock, 1.8 V levelSSC_QUP_I2C
46GPIO190_I2C_SDAI/OI2C data, 1.8 V levelSSC_QUP_I2C
48GPIO_201*I/OGPIO201, 1.8 V level
50GPIO_200*I/OGPIO200, 1.8 V level
52GPIO_199*I/OGPIO199, 1.8 V level
54GPIO_198*I/OGPIO198, 1.8 V level
49USB0_SBU2I/OUSB0 SBU signalFor Type-C
51USB0_SBU1I/OUSB0 SBU signalFor Type-C
53USB0_CC2I/OUSB0 CC signalFor Type-C
55USB0_CC1I/OUSB0 CC signalFor Type-C
56GPIO197*I/OGPIO197, 1.8 V level
58GPIO196*I/OGPIO196, 1.8 V level
57RGB_BLUEAOBlue LED high-side current source
59RGB_GREENAOGreen LED high-side current source
61RGB_REDAORed LED high-side current source
60GPIO_154I/OGPIO198, 1.8 V levelConfig pin, must not pull up during boot
62USB0_CC_DIRDOIndicates Type-C connection orientation
63,65FLASH_LED2AOFlash LED current source
67,69FLASH_LED1AOFlash LED current source
68,70VPH_PWRAO3.6 V output
75PM8550_GPIO11I/OPM8550 PWM3
73PM8550_GPIO8I/OPM8550 GPIO
14,21,27,30,37,47,64,66,71,73,79,72,74,76,78,80GNDGDigital ground
