ADB Login ​
Overview ​
ADB (Android Debug Bridge) is one of the most convenient ways to connect to the A8550MA1, requiring no additional display or network configuration.
Prerequisites ​
Windows Environment ​
  1. Download and extract the ADB tool package platform-tools
  2. Add the extracted platform-tools directory path to the system PATH environment variable
  3. Open CMD or PowerShell and run adb version to verify installation
Linux / macOS Environment ​
# Ubuntu / Debian
sudo apt install adb
# macOS
brew install android-platform-tools
Hardware Connection ​
  1. Connect the device using a USB Type-A to Type-C data cable
    • USB Type-A end to your computer
    • USB Type-C end to the A8550MA1's Type-C port
  2. Power on the device and wait for the system to finish booting (STATUS LED solid green)
Establishing ADB Connection ​
# List connected devices
# Example normal output:
# List of devices attached
# 47897135   device
If no device is listed:
  • Verify the USB cable supports data transfer (not charge-only)
  • Re-plug the USB cable
  • Try a different USB port on your computer
Common ADB Operations ​
Enter Shell ​
  • Method 1: Enter device command line with normal privileges
# Enter device command line
  • Method 2: Enter device with root privileges
# Obtain root privileges
adb root
File Transfer ​
# Upload files to device
adb push <local_file_path> <device_target_path>
# Example: upload test.py to /home/aidlux/
adb push test.py /home/aidlux/
# Download files from device
adb pull <device_file_path> <local_target_path>
# Example: download log file
adb pull /var/log/syslog ./
System Operations ​
# Reboot the device
adb reboot
# Enter flashing mode (EDL)
adb root
adb reboot edl
# View system information
adb shell cat /proc/version
adb shell cat /proc/cpuinfo
The current system does not support connecting via adb connect <device_IP>:5555.
