Core AI SDK Toolchain ​
AidLite SDK (AI Inference Acceleration) ​
AidLite SDK is APLUX's unified AI inference framework, encapsulating the Qualcomm QNN backend to achieve CPU/GPU/NPU heterogeneous acceleration, with a unified Python/C++ API.
Installation & Verification ​
# 1. Download the corresponding AidLite SDK package from the Documentation Center's "Resource Download Center"
# 2. Upload to the /home/aidlux directory on the A8550MA1
# 3. Extract and install
tar -xzf aidlite-sdk-ubuntu22.04-qnn236.tar.gz
cd aidlite-sdk
sudo ./install.sh
# 4. Verify installation
python3 -c "import aidlite; print(aidlite.get_library_version())"  # C++ library version
python3 -c "import aidlite; print(aidlite.get_py_library_version())"  # Python library version
Core Acceleration Types ​
Acceleration TypeDescriptionApplicable Scenarios
TYPE_CPUCPU general accelerationDebugging, lightweight models
TYPE_GPUGPU general accelerationImage processing, floating-point models
TYPE_DSPQualcomm DSP/NPU accelerationQuantized models, high-performance inference (recommended)
Standard Inference Workflow (Python Example) ​
import aidlite
import cv2
import numpy as np
# 1. Create model instance
model = aidlite.Model.create_instance(model_path="./yolov5s.qnn236.bin")
if model is None:
    print("Model loading failed")
    exit(-1)
# 2. Set model properties
input_shapes = [[1, 640, 640, 3]]
output_shapes = [[1, 25200, 85]]
model.set_model_properties(
    input_shapes=input_shapes,
    input_data_type=aidlite.DataType.TYPE_FLOAT32,
    output_shapes=output_shapes,
    output_data_type=aidlite.DataType.TYPE_FLOAT32
# 3. Create runtime configuration
config.accelerate_type = aidlite.AccelerateType.TYPE_DSP  # Use NPU acceleration
config.framework_type = aidlite.FrameworkType.TYPE_QNN
config.number_of_threads = 4
# 4. Initialize inference engine
ret = model.init(config)
if ret != 0:
    print("Inference engine initialization failed")
    exit(-1)
# 5. Run inference
img = cv2.imread("test.jpg")
img = cv2.resize(img, (640, 640))
img = img.astype(np.float32) / 255.0
input_data = np.expand_dims(img, axis=0)
outputs = model.run(input_data)
print("Inference result shape:", outputs[0].shape)
AidStream SDK (Streaming Media Processing) ​
AidStream SDK is a pipeline-based streaming media processing toolkit that supports hardware-accelerated video encoding/decoding, streaming (push/pull), and storage, designed specifically for AI video analytics applications.
Core Features ​
  • Supports multiple input sources including RTSP (H.264/H.265), files, USB/MIPI cameras
  • Supports hardware-accelerated video encoding/decoding to reduce CPU usage
  • Seamlessly integrates with AidLite SDK for end-to-end acceleration: video capture → preprocessing → AI inference → result output
Simple Pipeline Example ​
import aidstream
# Create a pipeline: USB camera capture → H.264 encoding → RTSP streaming
pipeline = aidstream.Pipeline()
pipeline.add_source("usb_cam", device="/dev/video0", resolution="1280x720", fps=30)
pipeline.add_filter("h264_encoder", hardware_accel=True)
pipeline.add_sink("rtsp_sink", url="rtsp://0.0.0.0:8554/live")
# Start the pipeline
pipeline.start()
AidCV SDK (Computer Vision Acceleration) ​
AidCV SDK is a GPU/NPU-accelerated computer vision library that provides an API fully compatible with OpenCV, optimized specifically for Ubuntu systems.
Key Advantages ​
  • Fully OpenCV-compatible API — migrate existing code seamlessly
  • GPU/NPU-accelerated image preprocessing operations (resize, crop, color conversion, etc.)
  • Native support for image rendering on Ubuntu desktop
Simple Example ​
import aidcv2 as cv2
import numpy as np
# Read image
# GPU-accelerated image resize
img_resized = cv2.resize(img, (640, 640))
# GPU-accelerated color conversion
img_rgb = cv2.cvtColor(img_resized, cv2.COLOR_BGR2RGB)
# Display image
cv2.imshow("Result", img_rgb)
cv2.waitKey(0)
