Build & Firmware Packaging ​
Prerequisites ​
  • Source code acquisition and environment dependencies are complete.
  • Use a regular user account for building; do not use root.
Enter the Build Container ​
For build environment consistency, use Docker for compilation.
Run the following command in the source root directory to enter the Docker environment:
docker run --privileged -it --rm --hostname $(hostname) -v $(pwd):/home/build $(whoami)/androidbuilder:u22 android
Ubuntu Build ​
build_qcs8550_lu.sh script syntax:
build_qcs8550_lu.sh user|debug version
Build the user (performance) variant:
./build_qcs8550_lu.sh user 01
AidLux Build ​
Enter the ubuntu/ directory and run Aidlux_build.sh:
Aidlux_build.sh user|debug version
cd ubuntu/
./Aidlux_build.sh user 01
Output Verification ​
After the build completes, check whether the image/firmware packages have been generated in the project's designated output directory, and record the corresponding version number for subsequent flashing.
Caution
Do not use the root user for building to avoid file permission anomalies that may cause subsequent process failures.
