Typical Scenario Demos ​
The A8550MA1 can perform on-device voice capture, speech recognition, semantic understanding, knowledge retrieval, translation, speech synthesis, and business control. AidVoice, the intelligent voice platform, combines these capabilities into pipelines, making it easy for developers to validate the full chain and further integrate it with their own devices and business systems.
AidVoice Intelligent Voice Demo ​
Demo Capability Overview ​
ScenarioInputProcessing PipelineOutput
Command ControlNatural voice commands such as "go forward", "turn", "lights"Voice capture → ASR → Intent recognition / Command formatting → Control interfaceStructured commands, device execution results, voice feedback
Real-time TranslationContinuous Chinese speech or short sentencesVoice capture → Streaming ASR → Translation model → Subtitles / TTSEnglish translation stream, subtitles, optional voice playback
RAG Knowledge Q&AVoice questions about local documentsASR → Question rewriting → Top-K retrieval → LLM answer → TTSKnowledge base-based answers, cited excerpts, optional voice playback
Meeting Transcription & SummarizationContinuous meeting speechStreaming ASR → Text caching / Segmentation → LLM summarizationReal-time transcription, segment summaries, final minutes & action items
Real-time Translation Demo ​
The real-time translation demo demonstrates the complete process of Chinese speech input, streaming recognition, English translation, subtitle display, and voice playback.
  1. Microphone captures Chinese speech.
  2. ASR outputs recognized text.
  3. The translation model generates English translations in streaming fashion.
  4. The application continuously refreshes subtitles.
  5. Optionally, TTS reads the translation aloud based on the scenario.
asr-demo
Demo Phase Metrics ​
PhaseReference Result
ASR output → First translation token~0.18 s
ASR output → Complete translation~1.14 s
Translation complete → TTS write~0.19 s
Streaming translations and phase latencies in runtime logs
Other Demo Reference Metrics ​
DemoKey PhaseReference Result (This Demo)
Command ControlASR output → Command output< 1.5 s
RAG Knowledge Q&AWake → ASR output~3.30 s
RAG Knowledge Q&AASR output → RAG retrieval complete~1.99 s
RAG Knowledge Q&AASR output → First answer character~5.27 s
Meeting Transcription & SummarizationText cache trigger threshold110 characters
Meeting Transcription & SummarizationTrigger → Model first packet~0.21 s
Meeting Transcription & SummarizationTrigger → First summary character~0.68 s
Test Notes
The above data comes from phase recordings under the current demo configuration and is intended to illustrate the pipeline and establish acceptance criteria. Actual results are influenced by model version, input length, audio environment, system load, knowledge base size, and output length. Please refer to the target version and actual test environment.
AidVoice Demo Downloads ​
Go to the Reference Design Materials page to download the demo source code.
Project Integration Approach ​
  1. Determine the scenario: Select a profile such as voice control, real-time translation, knowledge Q&A, or meeting summarization.
  2. Select components: Enable ASR, TTS, LLM, RAG, translation, and device control interfaces as needed.
  3. Configure business rules: Set trigger conditions, prompts, knowledge bases, output formats, and exception handling policies.
  4. Integrate with customer systems: Connect to device APIs, databases, ticketing systems, or industry business platforms.
  5. Test and accept: Verify accuracy, phase latency, end-to-end latency, resource usage, stability, and execution success rates.
Tip
The AidVoice Demo can serve as a starting point for functional validation. Developers can keep the standard pipeline while replacing models, prompts, knowledge bases, and business plugins to create intelligent voice applications tailored to specific products.
