Core Board Introduction ​
Product Overview ​
This core board is based on the Qualcomm QCS8550, a flagship SoC for high-end edge AI and smart terminals. The QCS8550 integrates a hexa-core Kryo CPU, Adreno 740 GPU, 48 TOPS NPU, 8K VPU, and Spectra ISP, purpose-built for high-compute, high-stability scenarios such as robotics, industrial AI, high-end IPC/VR, and automotive applications.
This core board features strict material selection and design for ultra-slim applications. Its compact dimensions and rich interfaces facilitate integration into finished products, and it can be used in digital signage, interactive touch, consumer electronics, entertainment systems, and other industries.
Product Appearance ​
SOM8550 core board physical photos:
Front
Back
Physical Dimensions ​
ItemParameter
PCBA Dimensions40 mm × 40 mm (±0.5 mm)
Board Thickness1.0 mm (±10%)
Mounting Hole Diameter4 mm
Screw Hole Spec∮2.2 mm × 4 (±10%)
For detailed dimensional information, contact APLUX FAE at support@aidlux.com.
Specifications ​
CPU ​
The core board uses Qualcomm QCS8550 CPU in 1581 MPSP package, chip dimensions 15.6 × 14.0 × 0.56 mm.
ItemParameter
AI Performance48 TOPS (INT8)
CPU1× Kryo Prime @ 3.2 GHz + 2× Kryo Gold @ 2.8 GHz + 3× Kryo Silver @ 2.0 GHz
GPUAdreno 740
Process4 nm
Video Decode4K@240 fps / 8K@60 fps (H.264 / H.265 / VP9)
Video Encode4K@120 fps / 8K@30 fps (H.264 / H.265)
ROM ​
The core board's UFS interface supports up to UFS 4.0 Gear 5 Rate A, 1×2 lane. Default onboard is a single SK Hynix 128 GB UFS, expandable up to 512 GB.
RAM ​
The core board connects to LPDDR5X via EBI controller in PoP form factor, with a maximum frequency of 4266 MHz. Default onboard is 12 GB LPDDR5X, expandable up to 24 GB.
Power ​
The core board uses Qualcomm PMIC power solution to meet system power and CPU power-up/down sequencing requirements. It uses DC power with a typical supply voltage of 3.8 V.
Peripheral Resource Overview ​
The core board exposes the following interface resources via board-to-board connectors (Panasonic AXK600337YG / AXK680337YG series):
Interface ResourceQuantityPerformance Parameters
CSI5 groups4 groups 4-lane + 1 group 2-lane, DPHY V1.2 2.5 Gbps/lane, CPHY v2.0 13.68 Gbps/trio
DSI2 groupsTwo groups 4-lane, up to 3480×2160@120 Hz, 3360×1600@144 Hz
PCIe2 groups1× PCIe 3.0 2-lane (8 Gbps) + 1× PCIe 4.0 2-lane (16 Gbps)
USB1 groupUSB 3.1 Gen2, up to 10 Gbps, supports OTG, DP1.4 compatible, supports MST mode
SD1 group4-bit, supports SD 3.0 / SDR104, 1.2 V IO level only
SPI5 groups4 groups general-purpose SPI + 1 group dedicated SPI, master mode only
UART10 groups1 group debug + 1 group 4-wire + 8 groups 2-wire
I2C9 groups4 groups camera-dedicated I2C + 4 groups general-purpose I2C + 1 group sensor I2C
I2S2 groups1 group non-LPI I2S + 1 group LPI I2S
SWR1 groupSupports PCM / PDM / DATA data formats
GPIO50 groups50 GPIO resources
ADC2 groupsVoltage range 0–1.875 V, sampling rate 4.8 MHz
PWM2 groupsDerived from PM8550
Important Notes ​
Please observe the following key notes when assembling and using the A8550MA1 SOM module:
  • Environmental requirements: Relative humidity 0–95% non-condensing, operating temperature -25°C ~ +50°C, storage temperature -40°C ~ +85°C.
  • ESD protection: This product does not have built-in ESD protection. ESD protection must be designed on the carrier board.
  • Voltage level matching: Pay attention to voltage level matching when designing external interfaces.
  • High-speed signals: When designing high-speed signal interfaces, follow design guidelines for layout routing to ensure interface performance.
Document Information
  • Official product name: A8550MA1 SOM Module
  • Full product code: A8550MA1
  • Document version: V1.0
  • Release date: 2026-06-11
  • Classification: Public
  • Applicable scope: A8550MA1 SOM module and carrier board / product development projects based on this module
© 2026 Chengdu APLUX Intelligence Technology Ltd. Unauthorized reproduction, distribution, or use beyond the scope specified in this document is prohibited without written permission.
