Porting - Audio ​
Audio Path Diagram ​
Audio output/input paths on the 8550 platform:
Audio output pathAudio input path
WCD9385 HPH Playback and AMIC Recording ​
1. Modifying the Device Tree ​
Corresponding device tree file:
src/vendor/qcom/proprietary/audio-devicetree/kalama-audio-rb5-gen2.dtsi
Configure Routing: Set the audio paths and BIAS voltages required for playback and recording.
&kalama_snd {
    qcom,audio-routing =
        "AMIC1", "Analog Mic1",
        "AMIC1", "MIC BIAS1",
        "IN1_HPHL", "HPHL_OUT",
        "IN2_HPHR", "HPHR_OUT",
        "IN3_AUX", "AUX_OUT",
        "RX_TX DEC0_INP", "TX DEC0 MUX",
        "RX_TX DEC1_INP", "TX DEC1 MUX",
        "RX_TX DEC2_INP", "TX DEC2 MUX",
        "RX_TX DEC3_INP", "TX DEC3 MUX",
        "TX SWR_INPUT", "WCD_TX_OUTPUT",
Configure Codec:
&kalama_snd {
    asoc-codec = , , ;
    asoc-codec-names = "msm-stub-codec.1", "lpass-cdc", "wcd938x_codec";
Trim Dailink:
&kalama_snd {
    qcom,wsa-max-devs = ;
    qcom,wcn-bt = ;
Modify MIC plug detection level:
&kalama_snd {
    qcom,msm-mbhc-hphl-swh = ;
Disable DP association:
&kalama_snd {
    qcom,ext-disp-audio-rx = ;
2. Recording Test ​
Use agmcap for recording test:
qtitinymix 'TX DEC0 MUX' 'SWR_MIC'
qtitinymix 'ADC2 ChMap' 'SWRM_TX2_CH2'
qtitinymix 'TX SMIC MUX0' 'SWR_MIC5'
qtitinymix 'TX_AIF1_CAP Mixer DEC0' 1
qtitinymix 'ADC2_MIXER Switch' 1
qtitinymix 'HDR12 MUX' 'NO_HDR12'
qtitinymix 'ADC2 MUX' 'INP2'
qtitinymix 'ADC2 Volume' 12
qtitinymix 'TX1 MODE' 'ADC_LP'
qtitinymix 'DEC0 MODE' 'ADC_DEFAULT'
qtitinymix 'TX_DEC0 Volume' 68
qtitinymix 'AMIC2_MIXER Switch' 1
agmcap /data/test.wav -D 100 -d 101 -c 1 -r 48000 -b 16 -i CODEC_DMA-LPAIF_RXTX-TX-3
3. Playback Test ​
Use agmplay for playback test:
qtitinymix 'RX_MACRO RX0 MUX' 'HPH_L'
qtitinymix 'RX_MACRO RX1 MUX' 'HPH_R'
qtitinymix 'RX INT0_1 MIX1 INP0' 'RX0'
qtitinymix 'RX INT1_1 MIX1 INP0' 'RX1'
qtitinymix 'HPH_L Volume' 20
qtitinymix 'HPH_R Volume' 20
qtitinymix 'HPHL_RX_PGA' 'HPHL'
qtitinymix 'HPHR_RX_PGA' 'HPHR'
agmplay /data/test.wav -D 100 -d 100 -i CODEC_DMA-LPAIF_RXTX-RX-0
