APLUX Online AI Toolchain ​
Model Farm ​
The Model Farm is APLUX's official model resource platform, offering 400+ AI models optimized for Qualcomm platforms, including measured performance benchmarks and ready-to-use sample code.
Core Features ​
  • Query the inference performance of specific models on the A8550MA1 (latency, accuracy, memory usage)
  • Download optimized model files adapted for the QNN backend (supports INT4/INT8/FP16 precision)
  • Obtain corresponding Python/C++ inference sample code for each model
  • Reference model adaptation and optimization steps to migrate custom fine-tuned models
Standard Usage Workflow (using YOLOv5s as an example) ​
  1. Visit the Model Farm: https://aiot.aidlux.com/zh/models
  2. Filter chip platform: QCS8550, Computer Vision: Object Detection, search: YOLOv5s
  3. Find YOLOv5s, click to enter the detail page, view YOLOv5s-INT8-QNN236 model, check performance benchmarks
  4. Log in with your developer account, click Model & Code, download the model file and code package
  5. Upload to the A8550MA1 and extract
unzip YOLOv5s_Qualcomm_QCS8550_INT8.zip -d model_farm_yolov5s
  1. Run the test script:
# Enter the directory
cd model_farm_yolov5s
# Execute the script
python3 code/python/run_test.py \
  --target_model ./models/QCS8550/W8A8/cutoff_yolov5s_qcs8550_w8a8.qnn236.ctx.bin \
  --imgs ./code/python/bus.jpg \
  --invoke_nums 10
AIMO Model Optimization Platform ​
AIMO (AI Model Optimizer) is a web-based, zero-code model conversion and optimization platform that supports converting mainstream framework models to Qualcomm QNN format, with automatic quantization and performance optimization.
Core Features ​
  • Supports mainstream frameworks such as ONNX, PyTorch, TensorFlow, and PaddlePaddle
  • Built-in Qualcomm platform-specific operator library, significantly improving model conversion success rates
  • Supports automatic quantization and custom quantization, balancing accuracy and performance
  • Generates optimized models and sample code that can run directly on the A8550MA1
Standard Conversion Workflow (using YOLOv8s as an example) ​
  1. Visit the AIMO platform: https://aimo.aidlux.com
  2. Upload the source model file (e.g., yolov8s.onnx)
  3. Select target platform: QCS8550, target framework: QNN2.36
  4. Use the Netron tool to inspect the model structure and fill in input/output node names
  5. Set quantization parameters: select INT8 quantization, upload a calibration dataset (optional)
  6. Submit the conversion task and download the optimized model package after completion
  7. Upload to the A8550MA1 and load/run using AidLite SDK
AI Creator Visual Training Platform ​
AI Creator is an all-in-one AI development platform integrating data annotation, model training, and remote deployment, optimized specifically for edge applications.
Core Features ​
  • Supports pixel-level annotation: object detection, semantic segmentation, keypoint detection, OCR, classification
  • Pre-built six algorithm modules, supports multi-module serial composition (e.g., localization + segmentation + classification)
  • Automatically tunes training parameters — train models without professional AI expertise
  • Automatically converts trained models to QNN models adapted for the A8550MA1
  • Supports one-click remote deployment to connected A8550MA1 devices
