Porting - Peripheral Interfaces ​
1. I2C ​
  • Four I2C groups are in use on the APLUX board. View the corresponding nodes with the following command:
sh-5.1# ls -l /sys/bus/i2c/devices/i2c*
total 0
lrwxrwxrwx 1 root root 0 Jun  5 22:37 i2c-0 -> ../../../../devices/platform/soc/9c0000.qcom,qupv3_i2c_geni_se/988000.i2c/i2c-0
lrwxrwxrwx 1 root root 0 Jun  5 22:37 i2c-1 -> ../../../../devices/platform/soc/9c0000.qcom,qupv3_i2c_geni_se/98c000.i2c/i2c-1
lrwxrwxrwx 1 root root 0 Jun  5 22:37 i2c-2 -> ../../../../devices/platform/soc/9c0000.qcom,qupv3_i2c_geni_se/990000.i2c/i2c-2
lrwxrwxrwx 1 root root 0 Jun  5 22:37 i2c-3 -> ../../../../devices/platform/soc/ac0000.qcom,qupv3_1_geni_se/a90000.i2c/i2c-3
lrwxrwxrwx 1 root root 0 Jun  5 22:37 i2c-4 -> ../../../../devices/platform/soc/ae90000.qcom,dp_display/i2c-4
Corresponding Hardware Information ​
Device NameBase AddressGPIODevice Tree Node
i2c-098800020/21qupv3_hub_i2c2
i2c-198c00022/23qupv3_hub_i2c3
i2c-29900004/5qupv3_hub_i2c4
i2c-3a9000044/45qupv3_se4_i2c
Modification Example: RTC Chip INS5830B ​
The I2C pins used are GPIO20 and GPIO21.
kalama-pinctrl.dtsi configures the I2C muxing for these two pins:
qupv3_hub_i2c2_pins: qupv3_hub_i2c2_pins {
    qupv3_hub_i2c2_sda_active: qupv3_hub_i2c2_sda_active {
        mux {
            pins = "gpio20";
            function = "i2chub0_se2_l0";
        config {
            pins = "gpio20";
            drive-strength = <2>;
            bias-pull-up;
            qcom,i2c_pull;
    qupv3_hub_i2c2_scl_active: qupv3_hub_i2c2_scl_active {
        mux {
            pins = "gpio21";
            function = "i2chub0_se2_l1";
        config {
            pins = "gpio21";
            bias-pull-up;
            qcom,i2c_pull;
kalama-qupv3.dtsi configures the device tree node for qupv3_hub_i2c2, referencing the above pinctrl:
qupv3_hub_i2c2: i2c@988000 {
    compatible = "qcom,i2c-geni";
    reg = <0x988000 0x4000>;
    #address-cells = <1>;
    #size-cells = <0>;
    interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>;
    clock-names = "se-clk", "core-clk";
    clocks = <&gcc GCC_QUPV3_I2C_S2_CLK>,
        <&gcc GCC_QUPV3_I2C_CORE_CLK>;
    interconnects =
    <&clk_virt MASTER_QUP_CORE_0 &clk_virt SLAVE_QUP_CORE_0>,
    <&gem_noc MASTER_APPSS_PROC &config_noc SLAVE_I2C>;
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&qupv3_hub_i2c2_sda_active>, <&qupv3_hub_i2c2_scl_active>;
    pinctrl-1 = <&qupv3_hub_i2c2_sleep>;
    qcom,i2c-hub;
    status = "disabled";
kalamap-rb5-gen2.dtsi configures the RTC device tree node under qupv3_hub_i2c2:
&qupv3_hub_i2c2 {
    status = "ok";
    #size-cells = <0>;
    ins5830b: ins5830b@32 {
        reg = <0x32>;
        pinctrl-names = "default";
        interrupt-parent = <&tlmm>;
        interrupts = <14 IRQ_TYPE_EDGE_FALLING>;
2. SPI ​
  • Four SPI groups are in use on the APLUX board. View the corresponding nodes with the following command:
sh-5.1# ls -l /sys/bus/spi/devices/
total 0
lrwxrwxrwx 1 root root 0 Jun 11 06:45 spi0.0 -> ../../../../devices/platform/soc/ac0000.qcom,qupv3_1_geni_se/a84000.spi/spi_master/spi0/spi0.0
lrwxrwxrwx 1 root root 0 Jun 11 06:45 spi1.0 -> ../../../../devices/platform/soc/ac0000.qcom,qupv3_1_geni_se/a88000.spi/spi_master/spi1/spi1.0
lrwxrwxrwx 1 root root 0 Jun 11 07:16 spi2.0 -> ../../../../devices/platform/soc/8c0000.qcom,qupv3_2_geni_se/888000.spi/spi_master/spi2/spi2.0
lrwxrwxrwx 1 root root 0 Jun 11 07:16 spi3.0 -> ../../../../devices/platform/soc/8c0000.qcom,qupv3_2_geni_se/894000.spi/spi_master/spi3/spi3.0
spi0.0a8400032/33/34/35qupv3_se1_spi
spi1.0a8800036/37/38/39qupv3_se2_spi
spi2.088800064/65/66/67qupv3_se10_spi
spi3.089400080/81/82/83qupv3_se13_spi
Modification Example: CAN Chip MCP2518 ​
The SPI pins used are GPIO32 ~ GPIO35 (SE1's QUP type is configured as SPI in TZ).
kalama-pinctrl.dtsi configures the QUP muxing for these pins:
qupv3_se1_spi_pins: qupv3_se1_spi_pins {
    qupv3_se1_spi_miso_active: qupv3_se1_spi_miso_active {
        mux {
            pins = "gpio32";
            function = "qup1_se1_l0";
        config {
            pins = "gpio32";
            drive-strength = <6>;
            bias-disable;
    qupv3_se1_spi_mosi_active: qupv3_se1_spi_mosi_active {
        mux {
            pins = "gpio33";
            function = "qup1_se1_l1";
        config {
            pins = "gpio33";
            bias-disable;
    qupv3_se1_spi_clk_active: qupv3_se1_spi_clk_active {
        mux {
            pins = "gpio34";
            function = "qup1_se1_l2";
        config {
            pins = "gpio34";
            bias-disable;
    qupv3_se1_spi_cs_active: qupv3_se1_spi_cs_active {
        mux {
            pins = "gpio35";
            function = "qup1_se1_l3";
        config {
            pins = "gpio35";
            bias-disable;
kalama-qupv3.dtsi configures the device tree node for qupv3_se1_spi:
qupv3_se1_spi: spi@a84000 {
    compatible = "qcom,spi-geni";
    reg = <0xa84000 0x4000>;
    #size-cells = <0>;
    reg-names = "se_phys";
    interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
    clock-names = "se-clk";
    clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>;
    interconnects =
    <&clk_virt MASTER_QUP_CORE_1 &clk_virt SLAVE_QUP_CORE_1>,
    <&gem_noc MASTER_APPSS_PROC &config_noc SLAVE_QUP_1>,
    <&aggre1_noc MASTER_QUP_1 &mc_virt  SLAVE_EBI1>;
    pinctrl-0 = <&qupv3_se1_spi_mosi_active>, <&qupv3_se1_spi_miso_active>,
        <&qupv3_se1_spi_clk_active>, <&qupv3_se1_spi_cs_active>;
    pinctrl-1 = <&qupv3_se1_spi_sleep>;
