Software Stack Overview & Architecture ​
The A8550MA1 is a System-on-Module (SOM) based on the Qualcomm QCS8550. The module integrates processor, memory, and storage, can independently run Ubuntu 22.04, and connects to cameras, displays, networks, audio, and control peripherals via a companion base board or customer-designed carrier board.
In terms of AI processing capabilities, the typical usage is to perform data acquisition, preprocessing, AI inference, business processing, and result output locally on the A8550MA1. It can also provide AI services to customer host systems or business systems over the network or standard interfaces.
Software Stack Layers ​
LayerMain ComponentsFunction
Scenario Application LayerMachine vision, intelligent voice, multimodal interaction, RAG knowledge Q&A, robotics, and industrial applicationsImplements interaction logic, business workflows, and user interfaces for final products
AI Services & Application FrameworkAidVoice voice pipeline, AidGenSE LLM service, RAG service, AidStream media pipeline, customer-developed servicesCombines model capabilities into callable, integrable scenario services
AI SDK & Acceleration LayerAidLite, AidCV, AidStream, AidVoice, and other SDKsProvides model inference, image processing, audio/video processing, and voice capability interfaces, invoking heterogeneous compute resources such as CPU, GPU, NPU/DSP
System & BSP LayerAPLUX Full Image, Ubuntu 22.04, device drivers, runtime libraries, containers, and development toolsProvides the system runtime environment, peripheral support, application deployment, and debugging capabilities
Hardware Platform LayerQCS8550, LPDDR5x, UFS, and CPU, GPU, NPU/DSP, ISP, VPUHandles general-purpose computing, AI inference, image signal processing, and audio/video codec
Heterogeneous Computing Division ​
Compute UnitPrimary TasksTypical Applications
CPUBusiness logic, data scheduling, general-purpose computing, and service managementApplication services, protocol handling, post-processing
GPUGraphics rendering and image tasks suitable for parallel computingUI rendering, image processing, some floating-point models
NPU/DSPHigh-performance, low-power quantized model inferenceObject detection, speech recognition, classification, on-device LLMs
ISPCamera image signal processingMulti-camera input, image quality processing
VPUHardware video encoding/decodingVideo analytics, recording, streaming
Applications can select the appropriate compute unit based on model type, precision requirements, and real-time goals. SDKs like AidLite encapsulate the underlying inference backends, reducing the effort required to adapt applications directly to hardware interfaces.
Typical Deployment Modes ​
Integrated On-Device Deployment ​
Models, AI services, and business applications all run on the A8550MA1, directly connected to cameras, microphones, displays, and control peripherals. Suitable for smart terminals requiring low latency, offline operation, and data privacy.
On-Device AI Services ​
The A8550MA1 runs inference or LLM services locally and provides APIs to customer applications over interfaces such as Ethernet. The customer system handles the UI and business workflows, while the A8550MA1 handles compute-intensive AI tasks.
Customer Product Integration ​
The A8550MA1 is combined with a customer-designed carrier board, with sensors, cameras, displays, audio, and communication modules connected as needed by the product. Applications, models, and system images can be deployed and upgraded uniformly with the finished product.
From Model to Application ​
  1. Select or prepare a model: Obtain pre-adapted models from the Model Farm, or use the customer's own models.
  2. Convert and optimize: Use tools such as AIMO to complete model conversion, quantization, and platform adaptation.
  3. Deploy and infer: Load and run models on the A8550MA1 using components such as AidLite and AidGenSE.
  4. Scenario integration: Build complete applications by combining AidStream, AidVoice, RAG services, or customer business interfaces.
  5. Validation and delivery: Verify accuracy, latency, resource usage, stability, and exception recovery capabilities.
Software & Materials Delivery ​
CategoryMain Content
System ImageAPLUX Full Image, including Ubuntu 22.04, base runtime environment, and companion components
BSP & Development MaterialsKernel, device tree, peripheral drivers, build, and flashing-related materials
AI Development ComponentsAidLite, AidCV, AidStream, AidVoice, AidGenSE, and other SDK or service components
Models & ToolsModel Farm, AIMO model optimization platform, and corresponding examples
Examples & Scenario DemosBasic inference examples, LLM and RAG examples, intelligent voice, and other typical scenario demos
Tip
Specific components, versions, and delivery formats are subject to the firmware packages, SDK packages, and release notes for the corresponding version.
