Power Interface ​
Rhino Pi-A1 supports wide voltage DC input, 12V or 24V, power adapter should be at least 36W.
DC barrel power connector 12V 3A [DC5.5*2.5mm]
Hardware Connection ​
Use the included DC barrel power adapter cable to connect a DC12V/24V 3A power adapter to the mainboard power interface.
Normal Boot ​
Device firmware versions may vary, so LED status during boot differs. Refer to the following:
Integrated OS Firmware ​
  • Boot process: Power indicator blue LED stays on
Ubuntu Firmware ​
  • Boot process: Green LED away from power connector lights up and blinks, then both green LEDs stay on when system is ready.
