Ubuntu System Installation ​
Reminder
Flashing will format the system. Back up your data in advance.
Install Flashing Tools ​
Before using Rhino Pi, install the required software on your local Windows PC:
  • USB driver: USB_Driver_qud.win.1.1_installer_10061.1.zip
  • Flashing tool: QPST_2.7.496.zip
  • ADB tools: platform-tools.zip
Software download link: Download software toolkit
USB Driver Installation ​
  • Extract the USB_Driver_qud.win.1.1_installer_10061.1.zip file.
  • After extraction, double-click the setup.exe program and wait for the Qualcomm USB Drivers installation interface to appear. Follow the prompts and click next to complete the installation.
Flashing Tool Installation ​
  • Extract the QPST_2.7.496.zip file to the current folder.
  • Navigate to the extracted QPST_2.7.496 directory and double-click the QPST.2.7.496.1.exe program to start the installation.
  • Follow the prompts and click next continuously to complete the installation.
  • You can navigate to this directory and send the QFIL.exe program to the desktop.
  • The desktop icon is as follows.
ADB Tool Installation ​
  1. Unzip
  • Extract the platform-tools.zip file to the D drive.
  1. Configure ADB Environment Variables
  • Copy the path of the extracted platform-tools folder.
  • Right-click "This PC" and select "Properties".
  • In the pop-up settings window, click "Advanced system settings".
  • In the Advanced tab of the pop-up System Properties window, click "Environment Variables".
  • In the pop-up Environment Variables window, select the Path variable in the "System variables" section and click "Edit" below.
  • In the pop-up Edit Environment Variable window, click "New" and add the previously copied platform-tools path.
  • Click "OK" in sequence to save the variable settings and exit.
  1. Verify if the ADB Environment Configuration is Available
  • Open the cmd window and enter adb. No error is reported.
Switch to Flash Mode ​
  • After boot, use a USB Type-A to Type-C cable to connect the PC and device. Type-A goes to the PC USB port, Type-C goes to the device.
  • On Windows, press WIN+R, enter cmd, and run adb devices in the opened window. Connected devices should be listed. If not, wait a moment or reconnect the Type-C cable and run again.
  • Run adb shell reboot edl to switch to flash mode.
Configure QFIL ​
  • Open QFIL and click Configuration - FireHose Configuration.
  • In the Download Configuration window, set:
Download Protocol: 0-Sahara
Device Type: ufs
Enable Reset After Download
Keep all other options the same as in the screenshot.
  • Click OK to save.
Select Flash Port ​
  • Click Select Port, choose the 9008 port in the popup, then click OK.
  • After switching mode as described in Switch to Flash Mode, port 9008 should appear automatically. If not, power-cycle the device, switch mode again, and wait.
Select Build Type ​
  • Find Select Build Type and choose Flat Build.
Select Flashing File ​
  • Extract the ROM package. Example version: RhinoPi-A1-Ubuntu24.04-ver-0.8.4.
  • Find Select Programmer, click Browse... next to Programmer Path, and select the extracted ROM directory.
  • Select prog_firehose_ddr.elf, then click Open.
Select Flashing XML Files ​
  • Find Select Flat Build, click Load XML..., and choose the flashing XML files.
  • In the popup, select all files and click Open.
  • Another popup appears automatically; select all files and click Open.
Start Flashing ​
  • After all options are configured, click Download to start flashing.
  • Wait about 5 minutes. If successful appears, flashing is complete. If flashing fails, contact Aidlux after-sales support.
  • After flashing finishes, the system will reboot automatically.
