Tool Resource Summary ​
When developing with AgaRhy hardware products, developers need to pre-install some software on a local Windows PC in advance, such as the ADB debugging tool and the QPST flashing tool.
Software download link: Software Tool Package Download Link
USB Driver Installation ​
  • Extract the USB_Driver_qud.win.1.1_installer_10061.1.zip file.
  • After extraction, double-click the setup.exe program and wait for the Qualcomm USB Drivers installation interface to appear. Follow the prompts and click next to complete the installation.
ADB Tool Installation ​
  1. Unzip
  • Extract the platform-tools.zip file to the D drive.
  1. Configure ADB Environment Variables
  • Copy the path of the extracted platform-tools folder.
  • Right-click "This PC" and select "Properties".
  • In the pop-up settings window, click "Advanced system settings".
  • In the Advanced tab of the pop-up System Properties window, click "Environment Variables".
  • In the pop-up Environment Variables window, select the Path variable in the "System variables" section and click "Edit" below.
  • In the pop-up Edit Environment Variable window, click "New" and add the previously copied platform-tools path.
  • Click "OK" in sequence to save the variable settings and exit.
  1. Verify if the ADB Environment Configuration is Available
  • Open the cmd window and enter adb. No error is reported.
Flashing Tool Installation ​
  • Extract the QPST_2.7.496.zip file to the current folder.
  • Navigate to the extracted QPST_2.7.496 directory and double-click the QPST.2.7.496.1.exe program to start the installation.
  • Follow the prompts and click next continuously to complete the installation.
  • You can navigate to this directory and send the QFIL.exe program to the desktop.
  • The desktop icon is as follows.
aid-deploy-tool Installation ​
The version of the aid-deploy-tool is updated irregularly. Please refer to the aid-deploy-tool_0.11.0_x64-setup version for installation.
The aid-deploy-tool is a desktop tool installed on Windows computers. After installing the USB driver and ADB tool, and connecting the Windows computer to the AgiX device via a USB Type-A to Type-C cable, you can use this tool to quickly perform convenient operations such as device information reading, IP configuration, AidLux installation, device activation, OTA upgrade, backup and restoration, and log collection.
The installation method is as follows:
  • Download the tool via the software download link, then double-click the exe file with the left mouse button to start the installation.
  • In the pop-up installation window, follow the prompts to install. You can click "next" continuously with the default settings.
  • After installation, the tool will open by default.
