Browser Login ​
If your network has a DHCP server and can assign IP addresses to downstream devices, you can log in to the system through a browser.
Hardware Preparation ​
  • Mainboard: Rhino Pi A1
  • Power supply: DC12V 3A power adapter
  • Input device: USB Type-A to Type-C cable
  • Communication device: standard Ethernet cable
Software Preparation ​
Refer to Tool Installation and install the required tools below. Skip if they are already installed.
  1. USB driver
  2. ADB tools
Power On the Board ​
The board comes with Ubuntu preinstalled. After connecting a 12V power adapter, the system starts automatically.
  • During boot: the RGB green LED stays on and blinks.
  • Use a USB Type-A to Type-C cable: connect Type-A to the Windows PC USB port and Type-C to the board Type-C port.
  • Boot completed: the RGB green LED stays on without blinking.
Get the IP Address ​
  • Connect an Ethernet cable to any wired network port on Rhino Pi A1.
  • On Windows, press WIN + R, type cmd, and run the following commands to query the IP address:
# Enter the device
# Get IP address
ifconfig eth0
The output is similar to:
The inet addr field is the device IP address.
Log In to the Web Page ​
After obtaining the device IP address, log in to the Ubuntu AidLux Web interface as follows:
  • Ensure the PC and board are in the same LAN.
  • Enter http://ip:8000/login in your browser, and replace ip with the actual device IP address.
  • Username/password: aidlux/aidlux
Use the System ​
After successful startup, you can start using Ubuntu 24.04 on Rhino Pi A1.
